5th gen Clutch Replacement kit, seals, and bearings.
Old Jun 5, 2016 | 08:06 PM
Genes1s's Avatar
I'm planning to do clutch replacement on my 5th gen. Planning to use the Exedy stage 1
https://shop.exedyusa.com/exedy-oem/.../i-126161.aspx
Anyone has OEM part number for the following:
1. Lower oil pan gasket.
2. Upper pan gasket (if need be).
3. Rear main seal (RMS).
4. Axle lip seals (the ones seals the drive shaft against the tranny).
5. Crankshaft clutch pilot bearing.
Car has 178K miles, do you turn the flywheel or get a new one?
Old Jun 6, 2016 | 12:19 PM
Child_uv_KoRn's Avatar
Bad *** Newb
You only need the clutch kit, rear main (I buy whatever is cheapest and that's usually national) and OEM throwout bearing if you want to play it safe. Flywheel can be resurfaced or you can get opt for aluminum (no point if you're not stacking mods).
If the half moon seal is leaking, then you can have fun pulling the oil pan if you want. It's not worth the effort to me. Use rtv for the oil pan.
reallywildstuff
18
Oct 29, 2019 10:09 PM
KingLwood
Mar 16, 2016 04:40 PM
maxima297
Mar 11, 2016 06:27 AM
JSROOKS
Mar 9, 2016 09:41 AM
ac max 92
Mar 8, 2016 05:40 PM
