View Poll Results: Are you interested in a reflash for your 5.5 gen?
Yes, quit baiting me and do it!
49
90.74%
No
9.26%
Voters: 54. You may not vote on this poll
Interested in 5.5 gen ECU reflash? I have good news coming soon...
Old Jun 18, 2016 | 12:52 AM
Child_uv_KoRn's Avatar
Bad *** Newb
A poll to start the hype
Old Jun 18, 2016 | 04:21 AM
96SEmaxB's Avatar
Yup, what he said
Old Jun 18, 2016 | 05:12 AM
fat_kid's Avatar
Subscribed for moar
Old Jun 18, 2016 | 08:16 AM
murphys_law's Avatar
I may know something about this..
Old Jun 18, 2016 | 08:44 AM
nestorlugo's Avatar
Will I need to upgrade my ecu?
Do I have to reprogram my keys?
Will this eliminate my precats?
Do I need cams?
How many hp will I gain with my injen cai?
Just a handful of questions that may arise by this thread !!
Old Jun 18, 2016 | 08:46 AM
Bad *** Newb
Do I need cams?
Cruising for a bruising
Old Jun 18, 2016 | 07:32 PM
Cotozic's Avatar
Do I need cams?
Hahaha, all important questions to raise.
Old Jun 19, 2016 | 07:40 AM
losifanatic's Avatar
Please keep us posted on your progress. I'm highly interested in getting my done
Old Jun 22, 2016 | 07:33 PM
A little teaser.
Can anyone tell me what this is?
Old Jun 22, 2016 | 08:30 PM
nestorlugo's Avatar
Originally Posted by murphys_law
A little teaser.
35° ignition timing up top @+2°
Old Jun 22, 2016 | 09:54 PM
Bad *** Newb
BZZZZZZZ. Ign timing doesn't drop.
Old Jun 23, 2016 | 11:33 AM
As a matter of fact on most cars it should increase as rpm increases due to the combustion process taking place in a shorter time, therefore necessitating more ignition advance to make the maximum cylinder pressure happen at the optimum time in the pistons travel and stroke.
Old Jun 23, 2016 | 01:03 PM
JonBlz's Avatar
a.k.a. STuNtMAN
I would do it.... as soon as you can reflash our 5.5 ECU I will be one of the first to get it done...... I had my old 02 reflashed and it was great
Old Jun 23, 2016 | 01:36 PM
It's not a "can" merely a when.
chikd_uv_korn and myself have already flashed several of the 5.5 6 speed ecus.
Old Jun 23, 2016 | 04:30 PM
george__'s Avatar
how much?
Old Jun 23, 2016 | 04:55 PM
fat_kid's Avatar
Any potential problems with the re-flash?
Old Jun 23, 2016 | 04:56 PM
Originally Posted by george__
how much?
That's what I want to know.
I have a 5.5 6 speed
Old Jun 23, 2016 | 06:09 PM
Originally Posted by losifanatic
That's what I want to know. I have a 5.5 6 speed
No pricing at the moment, still working on a few things. Shooting for the middle of July before anything happens.
Old Jun 23, 2016 | 06:25 PM
nestorlugo's Avatar
Old Jun 23, 2016 | 08:09 PM
Bad *** Newb
Old Jun 23, 2016 | 08:24 PM
nestorlugo's Avatar
Yo I wonder who were the two azz holes who voted "NO"!!!
Fvckin noobs !!!!
Old Jun 24, 2016 | 04:39 AM
Added horsepower and torque .
Old Jun 24, 2016 | 07:32 AM
NmexMAX's Avatar
dot dot dot ...
A little teaser.
IVT, and it's already better than stock.... since it looks strikingly familiar to this.
Most say the Z33 has this to "compensate" for it's single stage IM.
Here's a comp of stock FWD IVT vs modified (Z33 style).
It does drop @ peak torque, but rises thereafter.
Old Jun 24, 2016 | 07:36 AM
Originally Posted by NmexMAX
IVT, and it's already better than stock.... since it looks strikingly familiar to this. Most say the Z33 has this to "compensate" for it's single stage IM. Here's a comp of stock FWD IVT vs modified (Z33 style). It does drop @ peak torque, but rises thereafter.
Correct, and correct.
Here's a 3D view of the "improved" cam timing.
3D view:
Old Jun 24, 2016 | 08:33 AM
NmexMAX's Avatar
dot dot dot ...
Explain all 3 dims, I'm good with 2 .. and the 3rd?
Old Jun 24, 2016 | 02:07 PM
Derrick2k2SE's Avatar
Fvckin noobs !!!!
Probably our resident "A33 TECH".
He's worried that this will stop the fuses from filtering amperes, split your battery and cause the motor mounts to fail.
Old Jun 24, 2016 | 02:52 PM
cornholio's Avatar
lols
can i vote no if i don't have a 5.5 gen?
Old Jun 24, 2016 | 03:03 PM
Bad *** Newb
Originally Posted by cornholio
lols
If you do, you'll be banned from the 5th gen section
Old Jun 24, 2016 | 03:17 PM
RPM, Degrees, and the one I'm sure you're wondering about is Load(or more specifically Base Fuel Schedule, which is essentially load.)
Old Jun 24, 2016 | 08:57 PM
fat_kid's Avatar
Would this fix the TB from being partially closed at full throttle?
Old Jun 25, 2016 | 07:51 AM
Bits incoming
<iframe width="420" height="315" src="https://www.youtube.com/embed/T_WWtxcbh6M" frameborder="0" allowfullscreen></iframe>
Old Jun 28, 2016 | 11:37 AM
At this point, timing, rev limits, electronic throttle, intake cam timing, fuel target(AFR), fuel compensation, idle target, and MAF transfer function are all editable, and more importantly flashable. This should allow 99% of applications to be tuned(extreme FI combos can be tuned, but not 100% like I would like, YET.) There are a few other things I am working on at the moment that would allow even more power. Not bad for the short amount of development time.
Old Jun 28, 2016 | 03:43 PM
nestorlugo's Avatar
Can't wait for my ECU swap!!!
Old Jun 28, 2016 | 04:37 PM
JonBlz's Avatar
a.k.a. STuNtMAN
Exactly what I want... subscribed in for the constant updates i will do this
Old Jun 28, 2016 | 06:22 PM
Nyshadow's Avatar
I'm down for some of this. :-D
Old Jun 29, 2016 | 07:10 AM
NmexMAX's Avatar
dot dot dot ...
I was under the impression that load was defined as airflow (maf signal/gm/s), RPM, and throttle angle?
FSM says [“Calculated load value” indicates the value
of the current airflow divided by peak airflow.] But I always remember somewhere they mentioning throttle angle. Either way, re-defining it to sa more useful thing is better.
Yeah this is all good news.
Old Jun 29, 2016 | 07:19 AM
I was under the impression that load was defined as airflow (maf signal/gm/s), RPM, and throttle angle? FSM says [“Calculated load value” indicates the value of the current airflow divided by peak airflow.] But I always remember somewhere they mentioning throttle angle. Either way, re-defining it to sa more useful thing is better. Yeah this is all good news.
That's not an incorrect statement as all those things are factored in to get the "base fuel schedule." The reason base fuel schedule is used is because it is how the ecu tables are setup.
Old Jun 29, 2016 | 12:53 PM
I'm in!
Will we have to send the ECU in to you?
Old Jun 29, 2016 | 01:56 PM
Bad *** Newb
Originally Posted by Derrick2k2SE
I'm in!
That would be the cheapest option. I'm sure we can acquire ECUs and send one, but then you would have to program the keys and it would be costlier.
Old Jun 29, 2016 | 02:32 PM
Cool, I have two ECUs and can program them back and forth in a few minutes.
