Aiming headlights with channel lock pliers
Old Jun 19, 2016 | 06:41 AM
mclasser's Avatar
So I don't have access to any of my tools at the moment except a pair of channel lock pliers in the trunk I use to remove the oil cap when topping off lol. My headlight's need adjusting pretty bad, as the throw is too low. Can I use the pliers on the adjustment screws? I know they're plastic and will be careful. Will the pliers fit back there? Strange post, I know
Old Jun 20, 2016 | 10:30 AM
Heel Til I Die's Avatar
You should be fine using them as long as the angle of the pliers will reach the adjustment **** and you'll still have room to twist it. The cheap white plastic toothed discs disintegrated on mine so I had to use some pliers to twist the metal ****. I ended up using some long reach needle nose pliers that were offset at the tip in order to get the angle just right and still be able to twist the ****. It's a little tedious with the lights mounted in the car, but definitely doable.
Old Jun 24, 2016 | 03:16 PM
mclasser's Avatar
It was a little tight but the pliers did the job. The aim was pretty jacked up. Had to bring each headlight up a good amount. Now the shoulder and road signs are actually illuminated!
ac max 92
May 22, 2016 02:19 PM
Mstones
May 15, 2016 10:09 PM
smplyamzng
May 1, 2016 11:36 AM
Ray Torres
Apr 30, 2016 02:11 PM
Durapoker
Apr 30, 2016 01:04 AM
