Clearing Fault Codes
Old Jun 22, 2016 | 12:51 PM
Larry Wysocky's Avatar
I was told that pulling the fuse to the car's computer or simply disconnecting the battery will wipe the computer's fault memory and clear any current faults that were showing. My question is: If this is done to clear a P0440 EVAP code, and whatever was causing the code has not been repaired, how long would it then take to go active and illuminate the SERVICE ENGINE SOON light again?
Old Jun 22, 2016 | 02:59 PM
NmexMAX's Avatar
dot dot dot ...
Not exactly sure as it varies, but if it wasn't fixed, it WILL come back
Old Jun 22, 2016 | 03:01 PM
nestorlugo's Avatar
When it detects the fault again! Usually in a couple drive cycles
Old Jun 22, 2016 | 03:04 PM
What do you mean by drive cycle? Someone told me that it could take up to 20 key turns or 60 miles of driving
Old Jun 22, 2016 | 03:19 PM
NmexMAX's Avatar
dot dot dot ...
It really does vary. My primary O2’s are DC’d, and sometimes the light will come back the next key turn, sometimes not for up to 300 miles, (up to 6x key turns). Just fix the problem.
Old Jun 22, 2016 | 03:26 PM
Child_uv_KoRn's Avatar
Bad *** Newb
And, no, it will never pass emissions
I guess you could fool a buyer.
Old Jun 23, 2016 | 05:29 AM
They did...and I got fooled. Now I'm just pissed and want to try an prove that that is what he did to misrepresent the vehicle.
Old Jun 23, 2016 | 08:26 AM
Itz Shak's Avatar
Ouch, private seller or dealer?
Old Jun 23, 2016 | 10:33 AM
private seller...fracking kid...was cool to begin with, then clammed up and claimed "as is" Karma will be a ***** for him.
Old Jun 23, 2016 | 04:08 PM
Bad *** Newb
Evap codes aren't a big deal. This can be a gas cap or crack in the charcoal canister/hose. Get under it and inspect it.
Old Jun 24, 2016 | 07:34 AM
NmexMAX's Avatar
dot dot dot ...
That's pretty much the best type code to have IMO. Even if it's FUBAR'd under the car, easy and cheap fix.
qstick777
Jul 13, 2017 03:20 PM
QueensMAX
35
Apr 12, 2016 01:16 PM
Noela
Mar 31, 2016 07:24 PM
Muswagon
Mar 28, 2016 07:45 PM
