VIAS vacuum lines in 01 Maxima
Old Sep 16, 2016 | 06:42 AM
maximatech12's Avatar
OK why not just use universal vacuum lines at Auto Parts store?
Old Sep 16, 2016 | 07:23 AM
Reallyslowrio's Avatar
Universal vacuum line will work, but, buying the NWP blockoff plate is more fun.
Old Sep 16, 2016 | 09:09 AM
DennisMik's Avatar
Where did you get the idea that you can't?
Old Sep 16, 2016 | 11:27 AM
the lines in green have this ECO< 3*1104 ----- is this number referring to size?
>ECO< 3*1104 in green
Old Sep 16, 2016 | 12:08 PM
I think it's 3/16". Last time I just ripped the broken line off at the oreilly parking lot and bought some bulk hose the same size.
Old Sep 16, 2016 | 12:32 PM
3/16" is 4.7625mm.
Is this inner or outer diameter?
There are usually two numbers when buying this type of vacuum line.
An inner and outer number.
3*1104 this could be 3.1104 mm - inner diameter?
Old Sep 16, 2016 | 07:12 PM
Derrick2k2SE's Avatar
http://www.harborfreight.com/6-in-di...ngs-68304.html
Old Sep 22, 2016 | 07:24 AM
Digital Calipers are nice tools but no one should need one for this.
All these cars are identical so there is only one answer
Universal is all that's available
5/32" tubing for the VIAS vacuum tubes. it's universal windshield washer tube/vacuum line.
Universal PCV hoses have to be used as replacements
there are three sizes
1. .343" or 3/8" tubing for the PCV valve to intake collector.
2. .468" for valve cover to valve cover tube
3. .593" For valve cover to air cleaner.
you could go to Nissan and pay $120 or go to local parts store and get this for under $20.
Old Sep 22, 2016 | 08:20 AM
Also note that hose/pipe is measured by the ID and tubing is measured OD
Old Jun 9, 2017 | 09:25 PM
PCV lines are all 1/32
I'm pretty sure the one PCV
11/32
The valve cover to valve cover is
13/32
And the bigger PCV is
19/32
The Vacuum lines seem to be about 9/64"
Old Jun 9, 2017 | 10:39 PM
SubwayVQ's Avatar
Nissan had to use different vacuums lines for emission purposes! The diameter of the hose dictated the amount of flow so they had to either restrict or increase the size in some areas. It has to be this way.
southeast_first
Dec 27, 2016 02:45 PM
03maxima1
Sep 15, 2016 08:45 AM
Turbobink
Sep 12, 2016 06:11 PM
03impala9c1
Sep 11, 2016 04:44 PM
