Problem with only left rear toe
I have my car annually checked for alignment. The latest check the tech says the rear left toe is way off -0.34 degrees, range is -0.13 to 0.22 and its not adjustable. My previous alignment check (a little over a year ago) showed 0.12 degrees. The right side is 0.11 whereas a year ago it was 0.18 but still in range.
I've done a search and there is mentioning lowering will impact the toe/camber but my car has been lowered for years so this does not seem to be lowering. Any suggestions of what I should be looking for?
Thanks in advance.
Thanks in advance.
Thanks. No, not that I am aware of. I maybe should have mentioned that over the last 24 months I did replace the original shocks and struts with Tokico Blues. But the car has been handling great. I didn't get a chance to talk to the tech about the reading so I'm going to call them in tomorrow. I did also have to replace the lower front tie rods about a year ago but none of this seems relevant. I think they may have rushed the process.
You are precious. Now, stop posting.
Sounds like the car has been curbed at some point if the reading is accurate. It's bent a little. You can't do anything about, so try to forget it lol.
If the tire is wearing evenly, then nothing is wrong.
Thanks. The ESM does not show a rear control arm. But the wheel does show some minor curbing - nothing major though. I was wondering if the Stillen RSB I installed years ago may be causing this problem. Car drives fine but I would think a toe-in on the rear wheels probably only shows wear. I will pop the wheel off when I get some time to see.
