02 maxima
Old Oct 26, 2016 | 09:39 AM
chrismaxima's Avatar
02 maxima
i have a 02 maxima 3.5 when i take off from a stop and it gets in 2nd gear it starts to clatter i can hear it good from driver side.put once i give it more gas it goes away just when it gets in 2nd gear at low rpms???? anybody else had this problme
Old Oct 26, 2016 | 09:47 AM
mclasser's Avatar
Mileage? Auto or manual?
Clattering could be from the engine, exhaust, or suspension. You gotta be more descriptive. Jack up the car and start looking for loose parts. Bang around the exhaust to look for a broken heat shield.
Old Oct 26, 2016 | 09:53 AM
Its a auto.n has 190,000 on it.i did check all over..i use 93 gas.but sometimes use 89..
Old Oct 26, 2016 | 10:23 AM
BlackoutSE's Avatar
If its anything like a strong vibration is could be the torque converter or something to do with the transmission
Old Oct 26, 2016 | 10:24 AM
maxiiiboy's Avatar
Yes, any one of the above, plus axles or engine mounts.
Old Oct 27, 2016 | 08:37 AM
maxinout93's Avatar
could be from the exhaust like a rattle from one of the pre cats breaking apart in the housing and just rattling around. I had an issue like that and it was difficult to diagnose because it sounded like it was a timing chain noise or an engine bearing noise, as most shops will have you believe.
Old Oct 27, 2016 | 09:15 AM
Prophecy99's Avatar
could be idler pulley classic rattle soudns like metal exhaust around 1700-2100 RPM , strong change in throttle removes noise, only consistent grandma throttle will make the rattle.
