2000 I30 Rear Brakes
Old Dec 3, 2016 | 03:36 PM
Anovice's Avatar
Last year I had the front brakes and rotors changed. I purchased Power Stop KOE 2280 from Rock Auto and my local mechanic put them on. I have been pleased with these brakes. I could have changed the rear brakes at the same time, but the mechanic said they had about 50% pad remaining and since I only put on about 3,000 mile per year, I decided to wait.
The local Nissan dealer had an oil chance special ($18.99 including rotation of tires) and I had that done today. I ask them to look at the rear brakes. They said I have about 30% remaining. They also mentioned that when I get my rear brakes replaced, new rotors will be required because the current ones are fairly rusty.
I looked on Rock Auto's website today and see two kits that will work. One is Power Stop KOE 1168 and the other KCOE 1168. The only difference is the latter includes calipers.
The Nissan dealer only mentioned brake pads and rotors, but since they took a cursory look, that does not mean I do not need new calipers. My questions are how does one know if new calipers are needed and should I just have the calipers replaced when the mechanic is changing the pads and rotors.
Thanks!
Anovice
Old Dec 3, 2016 | 05:11 PM
jackman's Avatar
It's not customary to replace calipers as a matter of routine. And I sure as Hell wouldn't replace OEM calipers that are working well with Chinese knock-offs that might not last six months. Unfortunately, Rock Auto is one of those companies that won't tell you where their products are made. I only buy from them if it's a brand I'm sure isn't Chinese, or if it's a small product I don't mind sending back after I read the box.
Old Dec 3, 2016 | 07:22 PM
mclasser's Avatar
Unless the pistons are seized or leaking, leave the factory calipers alone.
Old Dec 4, 2016 | 09:12 AM
Anovice's Avatar
Thanks!
I am going to leave well enough alone, including not changing the rotors and pads with 30% remaining.
Going forward, how will I know when I need to change the pads? Since I will be changing the rotors at the the same time, what would be wrong with waiting until I hear a squeal or a noise indicating that the pads are finished? As mentioned, I only put on approximately 3,000 miles per year (1,700 miles are on one trip all highway) and I am one mile for the mechanic.
Anovice
Old Dec 4, 2016 | 09:34 AM
mclasser's Avatar
You won't always hear a squeal when the pads are worn out. I caught my rear pads being down to nothing during a tire rotation. No noise, spongy brake pedal, nothing.
Old Dec 4, 2016 | 10:12 AM
jackman's Avatar
You're making a mistake. 30% is time to change them, and the rotors are rusty. Just get it done.
Old Dec 6, 2016 | 08:05 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Change the rotors and brake pads, the calipers unless they are shut, no need to do. Better safe then sorry on the pads
Old Dec 6, 2016 | 10:56 PM
AaronL's Avatar
Serious, possibly noobish question - why should you change your pads at 30%? Why not wear them down to 10 or 20%? Is it just to avoid any possibility of running the pads down to 0% (which is a good reason) or is there some other mechanical reason?
Old Dec 7, 2016 | 03:18 AM
BronxSleeperMax187's Avatar
Go on youtube and save $$$...this is easy bro. My car got 3 original calipers with 200k miles...I changed one almost A year ago cause the piston was so hard to turn in the rear I had no choice....that was easy too with A buddy of mines. I got mines from Autozone....still fine and car stops on A dime after doing all rotors pads and that one caliper all together....don't half A$$ things that can save ur life.
Old Dec 7, 2016 | 05:52 AM
Prophecy99's Avatar
im on my 4th set of rear calipers.....
Old Dec 7, 2016 | 06:47 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Replacing rotors b/c they're rusty? Lol. You'll be replacing them every 3k with that requirement.
Old Dec 7, 2016 | 10:04 AM
jackman's Avatar
There's no mechanical reason. It's just good practice not to wait until they're too thin. People who try to squeeze the last 5K miles from their pads always end up with the brakes grinding.
Old Dec 10, 2016 | 03:56 PM
maximatech12's Avatar
They do have brake caliper paint on the market.
Has anyone cleaned them up then paint them then reinstall them?
Old Dec 12, 2016 | 04:14 AM
Prophecy99's Avatar
yes and yes
