what is the stock engine compression for 5th gen
Old Jan 30, 2002 | 10:40 PM
bernie2000se's Avatar
Everyone who has a 5th generations:
Does someone know what the compression ratio is for the engine, someone said 9-1 is this correct??
thank you.. Bernie
Old Jan 30, 2002 | 10:58 PM
Sonic's Avatar
Unless I am very incorrect, the VQ30DE and VQ30DE-K both had 10:1 compression.
Old Jan 30, 2002 | 11:03 PM
K Pazzo 6's Avatar
Re: what is the stock engine compression for 5th gen
thank you.. Bernie
What is compression ratio-- or what does does it do?
Old Jan 30, 2002 | 11:09 PM
Sonic's Avatar
Hmm, how to explain this.... It's the ratio of the cylinder volume when it is at 'Bottom Dead Center'(which it would be at the end of an intake cycle) to the cylinder volume when it is at 'Top Dead Center'(at the start of the combustion cycle.)
Old Jan 30, 2002 | 11:15 PM
Sonic's Avatar
Or, in other words, how much the air/fuel mixture gets compressed during an engine cycle.
Old Jan 30, 2002 | 11:17 PM
Menasor's Avatar
Re: Re: what is the stock engine compression for 5th gen
Compression ratio is the volume above the piston at BDC (bottom dead center) divided by the volume above the psiton at tDC (Top Dead Center. Basically it tells you how much air fuel mixture will be compressed when the engine is in its compression stroke. The higher the compression ratio the more power an engine can produce, In theory, that is. This is out of my automotive tech book but in my own wording because theres more in the book.
Old Jan 30, 2002 | 11:19 PM
K Pazzo 6's Avatar
thanks...
Old Jan 30, 2002 | 11:24 PM
Sonic's Avatar
Re: Re: Re: what is the stock engine compression for 5th gen
Hmm, the first 3 sentences look familiar.
Old Jan 30, 2002 | 11:41 PM
Menasor's Avatar
Re: Re: Re: Re: what is the stock engine compression for 5th gen
Maybe because we were both typing the info at the same time only you finished first.
Old Jan 31, 2002 | 05:55 AM
ru4real's Avatar
Menacer's explanation was superior to yours.
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
