Help me diagnose a front end clicking
2003 6sp, 183k
Front end clicks when turning left, one full rotation of the steering wheel. Sound metallic and I can feel it in the steering wheel.
I've replaced:
Both CVs
Both control arms
Both struts
Both strut mounts and bearings, twice
Both sway bar end links
I'm at my wit's end. Any suggestions?
I've replaced:
Both CVs
Both control arms
Both struts
2003 6sp, 183k
I've replaced:
Both CVs
Both control arms
Both struts
I've replaced:
Both CVs
Both control arms
Both struts
I had the same thing after I replaced sway bar end links and control arms. Ended up being the end links not properly tightened in the right position. Id just give them a glance and make sure they are on good.
Make sure the links are torqued to the spec - forgot what the spec is, but check the FSM.
Problem solved. Ended up being a bad passenger side CV axle. Apparently Advance Auto only sells reman axles for the 6speed and I just got a **** one out of the box.
All is good now. Thanks guys.
