manual transmission compatibility
Old Jan 22, 2017 | 03:40 PM
aib13's Avatar
can a 2003 manual transmission be used on later year maximas?
Old Jan 22, 2017 | 04:13 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Unless you know for a fact it doesn't have the 3rd gear synchro grind...
Old Jan 22, 2017 | 05:57 PM
aib13's Avatar
Im kind of new to the terminology what does 3rd gear synchro grind mean
Old Jan 22, 2017 | 06:19 PM
AEKnight's Avatar
Slight grinding noise when shifting into 3rd gear. Double clutching with a slight rev match helps to make the grind not so bad.
Old Jan 23, 2017 | 09:01 PM
Derrick2k2SE's Avatar
Many 2002/03 trannys had a weak 3dr gear syncro which leads to a grinding when shifting hard into 3rd.
A better bet is to get a 2004-2006 tranny. They fixed the issue in 04. Even better is to get one with HLSD.
Old Jan 24, 2017 | 07:02 AM
Bad *** Newb
I'm 3 for 3 on HLSD with no issue. First and only open diff crunched.
Old Mar 14, 2017 | 04:42 AM
Rinard Pratt's Avatar
5sp swap
Does any one know if a 2000 5spd manual can be swapped with an earlier model 5spd? If so which yrs are compatible with out much part changes?
Old Mar 14, 2017 | 04:19 PM
4thGenTuner's Avatar
1995-2001 five speeds will all bolt up to a VQ30/DE-K. The 4th gens use (and some 2000 models built in '99) a VSS in the trans for the speedo. IIRC the '01s used the ABS sensors instead of a VSS. So yeah, anything in that year-range will work.
Old Mar 16, 2017 | 11:36 AM
Thanks for the info @4thGenTuner Also according to the haynes repair manual 95 and up manual transmissions have the same bell housing bolt pattern. The manual covers 93-2004 maximas. I am assuming that the bolt pattern for the manual transmissions for the 3.5 have the same bolt pattern as well. Correct me if I am wrong. If they do, do you know what parts would hsve to be swapped out to go with one from a later model?.or maybe even direct me to someone who may know if you can't answer the question. Also. Did some of 02-03 maximas come with the 5 spd manual transmission. Trying to weigh different options. Thanks again in advance.
Old Mar 16, 2017 | 09:50 PM
SubwayVQ's Avatar
02-05? (Correct me on the last year) Came with a 6spd, not a 5spd.
Old Mar 17, 2017 | 03:07 AM
Step 1. Throw away the Haynes manual.
Step 2. Find the FSM for your specific model year.
Step 3. Read the FSM.
Step 4. ?????
Step 5. Profit/Swap trans & drive happy.
All bs aside, if you're wondering if a 5 speed will bolt up to a VQ35, the answer is yes.....kinda. None of the 02-03 cars came with a five speed. Some altimas had the VQ35 and 5 speed, but the mounts are different. If I were you I would stick to what came in the car. Keep it simple unless you're ready to do some custom motor mount work. So to be clear, VQ30 = 5 speed VQ35 = 6 Speed. If you have a VQ35, find a newer HSLD 6 speed.
Good luck & happy motoring.
maxima-junky
May 6, 2020 08:34 PM
Viking Erik
Jan 22, 2018 07:10 AM
bhairya
41
Jun 14, 2017 08:16 AM
Max_P
Jan 21, 2017 09:35 PM
leomitz200
Dec 25, 2016 11:20 AM
