Suspension and Exhaust Options
Hey guys,
I'm not new to the 5.5 but I recently picked up a one owner 6spd with 74k miles on it. I'm moving from a 2016 Camry to a 2003 Maxima so obviously the ride is going to feel sloppy.
I daily the car so I'm looking at OEM replacements on shocks/struts and likely a RSB. I'm considering KYB GR2s all around, and a Progress RSB if I can find one.
Also, when I was part of this forum 10 years ago, Cattman was a reputable exhaust system, but from what I've read, he has closed up shop. I'm looking for a catback setup.
Thanks!
Thanks!
Go KYB they are good, I have them replaced my OEM to KYB a year ago, after having the car for 16 years since new. time to refresh my suspension components back to new condition due to rubber seal drying out and bushing and etc...
Also, how many miles did you have before your replaced with KYBs?
Not FantasticMadMax, but I had 503k km when I replaced the originals with KYBs that had 48k km. Ride quality is night and day, but not too soft for my liking. Just perfect. I don't think that you can make the 03 maxima as soft as the 16' camry as those are meant to be as soft as they can be for the price. I believe someone said that the Monroe All in Ones are the softest you can get for the maxima.
I replaced mine at 81k miles since it was old typically manufacture recommend at 60k miles. When I replaced it, wanted to keep close as the OEM since mine is the SE trim, so figured KYB would be the way to go. They were pretty stiff at first, but now I'm rolling at 4k miles with those and kept the car tight as it turns and corner pretty well.
Did you replace the top hats too? I'm trying to decide if that is needed or not.
I did my rear struts a week or two ago. You'll probably need new boots, mine were toast. My top hats were really rusty too @ 197,000 km in southern Ontario. (Salty). I reused them but the rubber isolaters were falling off.
I'm pretty much in the same boat, I bought a 5.5 Max with Tein springs which the owner said makes the ride lower by 1-1.5", and stock struts. The roads in the city are rough so I was looking at going back to OEM springs. Would OEM springs that increase the ride to stock height make the car absorb bumps a tiny bit better and make it ride smoother?
