Is the y pipe a bolt on, or to I need a torch?
Old Jan 31, 2002 | 12:27 PM
Greek to the Max's Avatar
Is the Y pipe a bolt on?
Old Jan 31, 2002 | 12:29 PM
Dario's Avatar
yes it bolts right up, put the torch away
Old Jan 31, 2002 | 12:33 PM
are u serious? where does it bolt in and out of?
Old Jan 31, 2002 | 12:38 PM
Dario's Avatar
not to sure what the parts are called but i know they are bolt on.
its bolts up to the cat I THINK, if you get sometime look under your car and you will notice where it bolts on
Old Jan 31, 2002 | 12:45 PM
oh, So its not the headers back eh....Will this upgrade work with stock stock cat and stock exhaust. How much louder will it be?
Old Jan 31, 2002 | 12:48 PM
djmaxski's Avatar
Yep, it will work. The only thing it replaces are the stock y pipe and the pre-cat(s) on the Cali-spec cars
Old Jan 31, 2002 | 12:49 PM
Dario's Avatar
yeah it will work with both stock and you will notice an increase in noise not disturbing when driving normal but especially at WOT
for example in my car at WOT it sounds real aggressive enough to make people turn and look at whats going on and it sounds like a hissing underneath its not bad but just sounds mean
Old Jan 31, 2002 | 01:57 PM
theMax's Avatar
your just replacing the stock y pipe, and eliminating 1 (cali spec) or 2 (fed spec) precats.
The ypipe bolts up to the front manifold (or front precat for cali spec) and to the rear manifold and also directly to the cat.
3 connections plus the hanger (bolts on also)
Old Jan 31, 2002 | 02:19 PM
BigDogJonx's Avatar
Greek,,
I just did the install two days ago with Jason Reynolds and it was a B!tch. I mean a good one. You have to first remove the cat entirely to make it easier to pull out the ypipe later.
Then you need to remove three bolts on each end of the Ys. There are three way up near the firewall, will need a extension (10") and a swivel joint, and a 14mm DEEPsocket. Then remove the 3 bolts also on the other end of the Y that ends straight and meets up with the calispec manifold. Then you will need a 12mm socket to loose 5 bolts on the calispec manifold. You need to loosen this to be able to get the Ypipe out, YOU ONLY NEED TO LOOSEN the calispec manifold bolts. Not remove them.
This will take about 2hrs. Hopefully you got the car on ramps and what not, otherwise it is going to be a B!tch.
Dixit
Old Jan 31, 2002 | 05:02 PM
Cutler's Avatar
Originally posted by BigDogJonx
Greek,,
Dixit
Don't forget not to buy the Trak Auto Swivel Joint attachment, spend some $$ on a craftsman, if it breaks get a new one, hehe.
Old Jan 31, 2002 | 05:47 PM
BigDogJonx's Avatar
Oh yeah baby, that piece of $hit is useless. Jason knows what I am talking about, that thing kept falling apart.
Dixit
Old Jan 31, 2002 | 08:25 PM
silentbuzz's Avatar
GUYS, If I buy the part, I'll pay to have it installed. Im not Italian. Im Greek.
Old Jan 31, 2002 | 08:32 PM
Cutler's Avatar
It is very easy to install, at least it would be now that I know about that stupid lip on the inside of the y-pipe
Old Feb 1, 2002 | 12:28 AM
beemreatr's Avatar
how big is the y-pipe? can it be shipped through regular mail?
Old Feb 1, 2002 | 06:15 AM
BigDogJonx's Avatar
Yeas, The Ypipe can be shipped in a box that is about the same size as holding 20 4ft tube lights. Same Box I got mine in.
Dixit
litch
123
Jan 4, 2024 07:01 PM
Quickywd01
Sep 21, 2016 09:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
