Brake difference between 00-01 to 02-03 brakes
I have been searching for hours on here. links either are dead or info isn't known.
Anybody have concrete evidence,or info about the 5 and 5.5 gens brakes and the differences. Calipers ,rotors and brackets.
After over 2 1/2 hours of searching and reading i had enough.
yes the rear calipers are definitely difference and the brake hardware, I ran into that issue when I was rebuilding my rear calipers myself the parts are different from 00 and the 01 and the 02 and 03 are definitely different.
For the front,
95-01 = 11" rotor, single piston caliper
02-03 = 11.65" rotor, single piston caliper
Not sure if the actual caliper is different but the rotors and brackets definitely are. Larger mounting bolts on the 5.5 bracket too. The knuckle needs to be drilled to use it.
thanks everyone keep the info coming.
i asked at advance auto. guy was not interested in helping, but said 01 and 02 maxima's had different part numbers. Doesn't tell me much
