Random Stall ?
Old May 13, 2017 | 10:53 AM
FlaMark's Avatar
Random Stall ?
Hi Friends,
Driving yesterday and descending down a bridge and as I applied the brake and car slowed down,..the car died???
I stopped the car, put it in park and it quickly fired back up. I then put it in drive and drove home. * I noticed the fuel was really low (bout 1/8 tank) and the fuel light was on, but i'm not sure that would have anything to do with it???
This morning i filled the tank and drove it to Autozone and got the codes
  • p1800 (EGR Solenoid)
  • p0128 (thermostat)
I removed the thermostat years ago, no problems as i live in the tropics (always hot here) and the car always warms up fast and remains at perfect temp (just below half way point). This morning i tested the Solenoid and it clicks open and shut....but not sure its working all the time.
What could have caused that random stall-shut down? This is the first time this has happened and i don't want to get stuck in the middle of nowhere.
  • Any ideas on what this could be?
  • Could low fuel be an issue (it was at 1/8 tank and the gas light was on ???)
Thanks for any constructive input you can give.
~M
Old May 13, 2017 | 12:31 PM
wellshii19's Avatar
Yes most likely the fuel .
I had a '97 le sabre that used to that.Fuel was always low when it did.
Depending how steep the grade was,all the fuel might been tilted far enough where the pump couldnt grab it no more.
Could also indicate a failing fuel pump where, or messed up fuel sending unit(your fuel lower than it actually is)
Dirty injectors could also add to the problem. Cars are domino effected.
Old May 13, 2017 | 12:34 PM
wlong01's Avatar
Agree with wellshii19. More than likely low fuel in the tank coupled with an incline causing the remaining fuel to pool at one end of the tank starving the engine.
Don't let the tank go that low especially if you're in a hilly area.
Old May 13, 2017 | 12:49 PM
wellshii19's Avatar
This.
Always keep at least half a tank.
Old May 13, 2017 | 01:25 PM
FlaMark's Avatar
^^Thanks guys....appreciate the input.
I don't know bout this guys. I've run low many times, and have a theory that cars get better mileage with less weight (gas in the tank), but i could be wrong. I was coming off a moderate sized bridge (not too many "big bridges" in Fla, UNLESS you are crossing the inter-coastal and i wasn't). POINT is, i've run low before and it's never "gone dead" like that but maybe your right.
Not sure if those codes mean much, p1800 is a VIAS controller that tested working but its old.
HOPEFULLY it was a fluke and won't happen again. (i'm just paranoid i guess).
Old May 13, 2017 | 01:47 PM
wellshii19's Avatar
Fuel pumps fail slowly.
Clean your injectors,
check the fuel filter. Could also have dirt in the tank then on a bridge dirt will block the strainer/sock and cause stalling as well.
Hopefully it wont do it again.Let us know!
Old May 14, 2017 | 08:52 AM
FlaMark's Avatar
Thanks well,
Which fuel injector and fuel filter cleaner do you recommend?
Are they different or can they be the same?
~M
Old May 14, 2017 | 08:57 AM
SubwayVQ's Avatar
Thanks well,
~M
Replacing the fuel filter is easier than cleaning it, just takes patience. Just pick up a can of injector cleaner and look up a video on how to set up a rig to squirt it through.
Old May 14, 2017 | 11:23 AM
maxiiiboy's Avatar
Yes, most likely it's something in your fuel system. However, it could also be your MAF - don't be blind to that possibility.
Old May 14, 2017 | 12:13 PM
MichMaxFan's Avatar
I had similar situation but with plenty of fuel and on level ground but coming to a slow stop. Did it 2-3 times over a couple of weeks last winter. Cleaned the MAF and I'm unsure if it solved it or not but it hasn't come back.
My fuel pump has been noisy off and on when starting the car over the past few years but never a stall until last winter and it's not always noisy upon startup. After researching Schaeffer neutra 131 I've been putting it in nearly every fuel fill and I'm nearly certain that it completely quiets the pump. A few times I've heard the pump and I'm pretty sure those times were when I had not added the additive.
Might be something to also think about.
Old May 14, 2017 | 02:07 PM
2k2albatross's Avatar
FlaMark,
I was always told that when you run low the fuel pump has to deal with the sediment at the bottom of the tank. I try to always stay above 1/4.
Old May 14, 2017 | 02:57 PM
maximatech12's Avatar
Originally Posted by SubwayVQ
Replacing the fuel filter is easier than cleaning it.
Not really. You'd have to go Nissan on this because once you take it out you won't find one that fits anywhere in town.
The replacement strainer will NOT fit and do not have the plastic framing inside to support the fuel flow.
You'd have to replace the pump to get the strainer.
For this you need JECs pump from Nissan.
Old May 14, 2017 | 06:47 PM
MichMaxFan's Avatar
The strainer thing is replaceable, as it fits on bottom of pump. I don't know why someone would do anything other than replace the filter and/or screen.
As to fitment of the strainer, it sure seems that would be doable, and I believe it can be bought as part of the filter as well so....?? I'm not following some comments.
Old May 17, 2017 | 01:33 PM
FlaMark's Avatar
Hey guys,...my car stalled again. Making me nervous stalling on a deserted street somewhere, is not kewl
What could it be;
  • MAF (I saw this thread on cleaning the MAF, but some people said it really didn't work). LINK
  • Fuel Filter change? I was looking at this link,...but where should i buy a fuel filter? LINK
  • Gas Treatment?--- Which one is best?
  • Clean Fuel Injectors?---anyone got a link for that?
THANKS!
Old May 17, 2017 | 02:30 PM
Tarzan's Avatar
Fix the EGR code before you dump money into any other repairs. EGR system gets clogged in Nissans, clean the valve and if you can clean any pipes as well. you are going to need gaskets. Do one thing at a time and see if there is any improvement.
When EGR is at fault, the ECU may start throwing other codes randomly as well.
It probably won't hurt to run a can of SeaFoam through the tank of gas to clean the injectors.
Old May 17, 2017 | 02:48 PM
THANKS!
Cleaning them may not do much.
This is what I thought I could have done.
I found out just replacing them to be the way to go.
Hitachi or Bosch/Unisia is best
If you jump them off only run 10amps at 12V through them ​​​​​. Too many amps could fry the solenoid.
Old May 17, 2017 | 03:58 PM
5thgendriver's Avatar
go ahead and buy a maf sensor to see if it fixes your issue as it's only a matter of time before you'll need one anyway. I keep a spare in the trunk as I've already has to replace one.
Old May 17, 2017 | 04:35 PM
FlaMark's Avatar
SLIP and TCS OFF,plus check engine light
Ok....it did it again, but this time COMPLETELY conked out. I pulled the following codes
p1800
p0345 (pulled twice)
I wonder if its just the VIAS sensor issue or the camshaft position sensors are gone too....???? ALSO, are both the Sensors bad or just one ???
Thanks!
Old May 18, 2017 | 07:32 AM
Tarzan's Avatar
You would get codes for cam and crank sensors, for starters.
If your cam sensors are a toast, you would be in the limp mode.
If your crank sensor is a toast, you won't start.
Deal with the EGR system first.
Old May 18, 2017 | 11:16 AM
FlaMark's Avatar
Thanks Tarzan...
I see no other codes than the ones i listed above. Why would i deal with the EGR (which i believe is the Air Flow valve....correct) I think that would be a different code. (i think that code is p0100)
p0345 is cam shaft sensor...I would think to change those first...no?
Old May 18, 2017 | 11:46 AM
Tarzan's Avatar
https://maxima.org/forums/5th-genera...ml#post9147730
Old May 23, 2017 | 07:08 PM
FlaMark's Avatar
Thanks buds.
Apparently after changing the cam shaft sensors, this fixed the problem. Code p0345 for the front n back sensors were the problem.
Old May 24, 2017 | 06:03 AM
Tarzan's Avatar
Are all codes gone now? There can be more than one issue occurring at the same time, so check if you are getting any more codes.
Old May 31, 2017 | 05:53 AM
FlaMark's Avatar
Hi Tarzan,...yes, all codes at this time appear to be gone. Thanks!
