Ac control lights dont work
I drive a 2002 nissan maxima gle the ac control lights stopped worning but it's only the middle bitton , the mode and the fan spees button the left side works fine is it im not sure if its a fuse or maybe they just burnt out
Does your A/C still turn on? If so, then the bulb is burnt out. If not, you will have to diagnose why not.
It shouldn't be that hard, just pull apart the climate control module and find the button/bulb you're looking for. It's more than likely held together with plastic snaps or small screws.
i did this already , adn same two burnt out again cpl years later, i think theres a more long term fix w like a solder , i feel one member figured out the real cause of the early burn outs.
the problem is the contacts on the board clean them with sand paper first
and the Eagles Suck
i need to get rid of that, i dont even like pro sports any more ! missed last two super bowls w pride.
thanks for that !! soudns right !! i need to replace mine a 2nd time and have blubs waiting to be put it, but its just blah ....for a cpl light bulbs rip out half of ur dash...
