Misfire, no light, no stored or pending codes, rattling/grinding noise.
Old Jun 11, 2017 | 08:47 PM
03VQMAX's Avatar
It started with a light tapping noise, now the noise is worse if its the same thing making noise. It's kinda like a ratting grinding noise. It's misfiring under load only. I've been looking around and aiming towards the VVT Solenoid but I'm uncertain. I have a few videos that hopefully can be uploaded. 2003 162K miles, stock everything, religious oil changes. Only let me upload RPM plunging, I"ll try again tomorrow with engine bay one.
File Type: mov
Old Jun 11, 2017 | 09:24 PM
SubwayVQ's Avatar
Could be a vacuum leak, try spraying carb cleaner around the intake and check hoses.
Old Jun 12, 2017 | 06:52 PM
j8lech's Avatar
What octane do you run?
If you're running lower than 93 put some in with some techron additive.
Old Jul 9, 2017 | 07:07 PM
03VQMAX's Avatar
Update***. I did the timing chain job. Still has the same noise. The secondary tensioners were a little worn, but not enough to make that obnoxious loud noise. This is frustrating. I feel like if it's coming from bank 1, the sound is coming from the intake manifold. It gets louder with RPM change. My buddy did find very light metal shavings on my oil pan. So I might sooner or later have to replace whole engine.
Old Jul 9, 2017 | 07:59 PM
SubwayVQ's Avatar
Have you pulled the VIAS butterfly valve out and checked it for noise? The screws can get loose and cause a rattle.
Old Jul 10, 2017 | 07:06 PM
03VQMAX's Avatar
first thing I did was a block off plate. But today after further diagnosis, I believe my lifters or cam bearings are shot
