hella horn install...positive or negative...
Old Jun 26, 2017 | 04:39 PM
5thgendriver's Avatar
which diagram do I use to install the relay...positive or negative.
thx
figured it out...
Old Jun 27, 2017 | 09:46 AM
DennisMik's Avatar
I hope you figured out that you don't need the relay, because there is already one built in by Nissan.
Old Jun 27, 2017 | 03:11 PM
thanks for the reply. yes...they are already hooked up without the relay. I was just wondering if I install the relay would it be louder.
Old Jun 27, 2017 | 06:43 PM
DennisMik's Avatar
Installing another relay would not make any difference to how loud the horn is. The loudness is determined by the design of the horn, the resistance of the coil, how many times it energizes and releases and the shape of the horn body that resonates the sound.
Old Jun 27, 2017 | 06:55 PM
yeah...i read something about voltage drop. since I have the relay and the wires I'll go ahead and install it to see if it makes a difference. I've read where some say it does and some says it doesn't.
Old Jun 27, 2017 | 07:34 PM
DennisMik's Avatar
I have installed Hella horns on my 3rd, 4th and 5th gen maximas as well as my 2 lexus cars. You are just giving yourself practice in installing a relay.
The only reason a relay would be needed is when the switch that operates said device cannot handle the amperage needed. And Nissan has a relay in the horn circuit for just this reason. I had 4 Hella horns on my 5th gen for a while and they worked just fine without any additional relay and wiring.
Old Jun 29, 2017 | 05:39 PM
relay made no difference...
with mine anyway...ymmv
they sure are purty tho.
Attached Thumbnails hella horn install...positive or negative...-20170629_152908.jpg
Old Jun 29, 2017 | 08:55 PM
DennisMik's Avatar
I painted all of mine flat black so they would be less obvious.
Attached Thumbnails hella horn install...positive or negative...-hella-horn-5.jpg
Last edited by DennisMik; Jun 30, 2017 at 02:35 PM. Reason: photobucket won't let you show images stored there!!
Old Jun 30, 2017 | 03:13 AM
I think I'll do the same ...and thanks for all your help.
Old Jun 30, 2017 | 02:40 PM
DennisMik's Avatar
That damn photobucket wants $100 a year for me to be able to display photos that I have stored there! Photobucket can kiss my bucket.
Old Jun 30, 2017 | 03:06 PM
wow...really? I guess that's why I keep seeing these weird photobucket 3rd party implants.
