Door removal
Old Jul 14, 2017 | 01:33 PM
PH98I30's Avatar
Door removal
Co worker has a 5th gen 2002 I30. Someone smashed in his passenger doors last week. Is there any tips to removing the car doors?
Old Jul 14, 2017 | 06:07 PM
Derrick2k2SE's Avatar
There's not too much to it.
It's easier with two people. If not, a jack with a towel on it will support the door while you mess with the hinges.
Disconnect the black plastic tensioner/stop first.
The harness has a block/plug that's held with one long 10mm bolt. A ratchet wrench helps get to it.
Have a place to put the door before you remove it. Somewhere safe to lean it and something soft to set it on so it doesn't scratch.
Old Jul 16, 2017 | 09:02 AM
CTMaximaSE's Avatar
If you can rolled down the window, its a little easier to handle moving the door around.
