Fog lights not working
Old Jul 27, 2017 | 03:30 PM
IAccess420@gmail.com's Avatar
Fog lights stopped working. Replaced fuse under driver side dash. Do I need to add a fuse to the passenger side (Under the hood?) FR Fog Lights i think it reads. Thanks. I have a hard time believing the lights are blown. The one on the passenger side was working in the past
Old Jul 27, 2017 | 04:24 PM
Somebody?
Old Jul 27, 2017 | 05:15 PM
SubwayVQ's Avatar
Originally Posted by IAccess420@gmail.com
Somebody?
You didn't even wait an hour before posting this. Are you expecting a reply immediately?
Old Jul 27, 2017 | 05:56 PM
You really dont want to **** with me. You have been warned.
Old Jul 27, 2017 | 07:07 PM
SubwayVQ's Avatar
I'm not trying to start anything. I'm just saying that this forum isn't as populated and active as it used to be, so you might not get a reply until hours later or even the next day.
Old Jul 27, 2017 | 07:41 PM
Derrick2k2SE's Avatar
3 posts in and you're WARNING us? Give me a break.
I could probably help you out but you can go f#&k yourself till you find some manners.
Old Jul 27, 2017 | 08:54 PM
maximatech12's Avatar
You have to switch them "on". The switch is by the light switch on the wand.
Also if that doesnt work theres a fog light relay.
Old Jul 28, 2017 | 05:58 AM
Wheres the relay and what do i have to do to it?
Old Jul 28, 2017 | 08:13 AM
5thgendriver's Avatar
https://maxima.org/forums/5th-genera...wont-work.html
Old Jul 28, 2017 | 10:16 AM
Relay is most likely in an electrical box.
If you unplug the fog light connector at the fog light then turn the switch on at the wand somehow check for the voltage this will eliminate any circuit issues.
Old Jul 28, 2017 | 10:25 AM
I believe the fog light relay is in the box on the pass side.
Old Jul 28, 2017 | 10:57 AM
so its by the windshield washer tank?
I cant recall off of the top of my head. The Toyota i got its by the battery on the drivers side.
Old Jul 29, 2017 | 08:32 PM
I wanna know how it went missing..
Now I have to buy another one.. but first I need the car to actually drive
Old Jul 30, 2017 | 08:18 AM
RLW001's Avatar
If the fog lights are cracked...moisture can cause the bulbs to fail.
Old Jul 30, 2017 | 06:38 PM
DennisMik's Avatar
I don't know how a relay could go missing without human intervention being involved.
What is the possibility that the fog lights are aftermarket? In that case a Nissan FR FOG relay would not be used. If that were the case, the way you turn them on would be different. The factory Nissan fogs have the on/off switch built in with the headlight switch.
