Music
Old Aug 5, 2017 | 09:31 PM
Devonvq's Avatar
Music
i got a sony single din in right now but the previous owner had failed at splicing the wires together so everything fell apart I don't know what I should do because all of the wires are different colors and google doesn't give me the color code
Old Aug 6, 2017 | 04:20 AM
DennisMik's Avatar
Did the previous owner cut the wire harness connectors off and splice directly into the Nissan wire harness? Or is there an adapter?
The Sony radio came with a short 6 inch (?) harness that plugs into the radio. Then most people get an adapter from Metra or Scoche that will plug into the Nissan wire harness. Then you solder the 2 adapters together.
So I need more info on what you have. I also need to know what the year and model of the car is because there were 2 different radio systems used. If you can post a photo of the car wiring that the radio connects to, that would be helpful.
Old Aug 6, 2017 | 12:03 PM
Devonvq's Avatar
2000 Nissan Maxima and the previous owner cut into the original harness there is no adapter that's why I'm confused on what I should do
Old Aug 6, 2017 | 03:26 PM
DennisMik's Avatar
At least you gave me the year of the car. That's one third of the information I need. What I also need to know (which is much more important) is what kind of radio system the car had originally.
Look in the trunk on the bottom of the parcel shelf. If the car was built with the Bose radio, there will be a speaker in the center of the parcel shelf and between the speaker and the passenger side there will be an amplifier module. If the car did not have the Bose, there won't be anything mounted to the bottom of the parcel shelf.
I am going to assume a non-Bose car. If this is incorrect DO NOT follow the below instructions.
The first thing you want to do is verify that the wire colors of the Sony harness match what is listed below. If there is a difference, let me know
Code:
2000 Radio Wiring
Sony to Non-Bose
                                        Non-Bose,
Signal               Sony Harness       Nissan Wire Harness  Pin #
Ground               Black              Black                  9
Radio power          Red                Purple                10
Station Memory       Yellow             Yellow                 6
Antenna              Blue               Green/wht stripe       5
LF Speaker pos       White              Blue/wht stripe        2
LF Speaker neg       White/blk stripe   Blue/yel stripe        1
RF Speaker pos       Gray               Brown                  4
RF Speaker neg       Gray/blk stripe    Brown/wht stripe       3
LR Speaker pos       Green              Light green           14
LR Speaker neg       Green/blk stripe   Black/yel             13
RR Speaker pos       Purple             Blue                  16
RR Speaker neg       Purple/blk stripe  Pink                  15
Amplifier Remote On  Blue/wht stripe    Green/wht stripe      12
Amplifier Ground
Illumination         Orange/wht stripe  Red/wht stripe         8
Dimmer                                  Red/yel stripe         7
Phone Mute                              Brown
