02/03 cooling fan part numbers
Old Sep 22, 2017 | 04:45 AM
PowerTotheMax's Avatar
I need a new cooling fan for my 02, and when searching AutoZone I found different part numbers for an 03. The 03 Dorman brand costs significantly less than the 02. Now, the image is slightly different, but I assumed the fans should be the same for the 5.5. Is that not the case?
Old Sep 22, 2017 | 07:46 AM
FanaticMadMax's Avatar
Is it the motor or the whole fan assembly? It possible that harness is changed in 2003, but I would look at yours and see exactly what you have then you can determine if the 02 and 03 are the same fan assembly
Old Sep 22, 2017 | 11:42 AM
Shape of shroud and number of fins are different. I'm not going to take the chance to try to save $30. I guess from 2003 forward the fans were changed.
Old Sep 22, 2017 | 06:16 PM
03VQMAX's Avatar
the fan motor that stays on the most has holes to dissipate heat, the other motor doesn't, plus I believe blade shape is different. Thats why I got OEM.
Old Sep 22, 2017 | 07:24 PM
Derrick2k2SE's Avatar
Rockauto.com has the motors cheap. They're all the same for the 5th gen.
Old Sep 22, 2017 | 09:46 PM
03VQMAX's Avatar
Old Sep 23, 2017 | 04:52 AM
Originally Posted by 03VQMAX
What did Ni$$an want for those?
Old Sep 23, 2017 | 05:17 AM
03VQMAX's Avatar
An arm and my first born $196 pop
Old Sep 23, 2017 | 07:55 AM
alanfury75's Avatar
+1 for the RockAuto fan motors. I bought a fan motor for my 02 about 2 months ago, and has been working beautifully.
Also, you'll want some washers on hand as it will sit a little closer to the condenser than stock... if you end up going that route.
Old Sep 23, 2017 | 12:28 PM
If I had time I would have bought just the motors but the loud grinding started so suddenly and I drive 60 miles a day Monday-Friday.
Anyway I'm hating myself for going ahead and getting the 03 assembly. It did not fit well and I could not return it anymore. It is a little more bulky. It's on but the bottom inserts are far more spaced out than the 02. I could only line up 1 mounting hole on top as well. Motors look identical so I will probably just swap the motors onto my old one if the assembly rattles too much.
Old Sep 23, 2017 | 01:40 PM
The motors are easy to swap.
Old Sep 23, 2017 | 02:10 PM
SubwayVQ's Avatar
Speaking of motors, now my driver side one stopped working. So I have to replace that one now hahah.
Old Sep 23, 2017 | 05:28 PM
Yeahhhh... I'll stick with the TYC fan motor from Rockauto for $36.00
