02 maxima loss of power
Old Oct 27, 2017 | 03:00 PM
Jmaxima86's Avatar
So I just about had it with this car and it's many issues , I can't seem to figure out what's causing my problem, check engine light is on and it's throwing a p0300 which is a random misfire and also throwing a p1800 which is for the vias, so far I've replaced all spark plugs, coils, checked for vacuum leaks , changed all the vacuum hoses , replaced both valve covers , did the 2k1 maf swap, and I'm just aggravated and running out of ideas , could be fuel pump related ? Car will be idling and then rpms dip low and engine light starts flashing, it also studders on acceleration and feels like it's struggling to catch speed , problem has been getting worse these past couple days , and the weird thing is it comes and goes , it seems to be intermitent, did ecu reset couple times , power comes back and it feels like a brand new car but after a couple days it runs like crap again , it's running like I have a 4 cylinder under the hood , any suggestions would be greatly appreciated, car has 140k atm and it's 6 speed , I can say I have a love hate relationship with this car right now I just want to be able to feel the vq35de glory again ...
Old Oct 27, 2017 | 11:55 PM
maxiiiboy's Avatar
Check your ground distribution and continuity. Obviously, you need to check it when the car is misbehaving.
Old Nov 2, 2017 | 05:12 PM
maximatech12's Avatar
Engine light flashing is bad TWC.
Basically its saying you have unburned fuel passing into the catalytic converter and theres a melt down.
Do you have a puff of whit smoke at start up?
When you pull the plugs do some appear wet?
You may need a few new injectors.
Old Nov 8, 2017 | 05:59 PM
Theslaking's Avatar
It did it to me a couple times when I first bought mine. Checked the plugs and some were 3 times the recommended gap. All 6 were at least double. Switched them out bam. Brand new engine. So if you did plugs and it's random, some type of timing issue.
