clutch master cylinder quick fix
Old Jun 22, 2018 | 11:31 PM
uptownsamcv's Avatar
the other day my clutch pedal lost pressure and the fluid was full. when i pulled the reservoir cap off it was real hard to take off, I can only assume the seal is swollen. so i pumped the pedal a bit and the pressure came back. about half an hour later the pressure dropped again. i ended up just drilling a vent hole in the center of the cap and cut a circular hole in the seal right under the hole drilled into the pump. its been 3 days since i did this and I haven't had any issues so far. no fluid leaking out from the top of the cap either....
Old Jun 22, 2018 | 11:34 PM
Child_uv_KoRn's Avatar
Bad *** Newb
It'll work until it absorbs a lot of moisture and then bye bye pressure when you need it.
Trash stock clutch line and bleed it, then seal that hole.
Old Jun 22, 2018 | 11:39 PM
this is temporary and just for testing, just wanted to make sure the cap really was the issue. will be picking a new one up at Nissan as soon as I get a chance to stop by...
cashoit
22
Sep 7, 2011 08:05 AM
Kiosk
Apr 10, 2011 06:26 PM
Eenis
Jan 7, 2006 03:07 PM
williamconor
Oct 1, 2004 10:29 AM
3rdgenmaxima
May 5, 2004 05:11 PM
