P0227 P0226 Infiniti I35 2002
Old Jul 26, 2018 | 11:33 AM
ghmmhg's Avatar
Download the repair manual.
Did every step pointing towards the Code.
- 73 in ecm is having low voltage. It is suppose to be between 0.41-0.71v when released. I can only get .11v, other positioning works fine. When press down and the sensor 2 too.
However, I want to be positive.
check TB harness, volts, continiuty. Everything Fine until I tried to do the "throttle closed valve position learn". After doing it, the relay activates, but the throttle won't move at all even after waiting the 10 seconds. Is it normal? Since I have probably the APP sensor problem?
I'm doing this 'cause the car was traveling in a lot of pot holes during the incident and don't know if there is something loose.
Old Jul 26, 2018 | 12:25 PM
ghmmhg's Avatar
stas29
Aug 24, 2013 06:19 PM
Maximus44
Mar 18, 2002 09:31 PM
MarkP
Jun 4, 2001 06:08 PM
max2kgle526
May 11, 2001 11:26 PM
