Will auto and manual dash harness be the same?
Old Aug 6, 2018 | 04:08 PM
Violator's Avatar
There's 2 pull it yourself junkyards an hour from me each with an 02 maxima. It would be nice to get the M/T ECU NATs and ECU harness while I'm there but my main concern is cutting out the 10 or so connectors I need from the main dash harness for my full 3.5 swap into a 4th gen. Would this harness be the same regardless of manual/autotragic transmission? Wish these pull it yourself junkers would actually note down the transmission type in their inventory
Old Aug 7, 2018 | 03:12 AM
Theslaking's Avatar
You can Google the car with the VIN or ask Nissan what was originally in the car. ImIsure the yard has the VIN on file so you don't have to drive there first.
Old Aug 8, 2018 | 03:30 PM
DennisMik's Avatar
There is a sticker on the firewall of the car on the passenger side. It will have the VIN on it but below it is a line called the ID #.
The 7th character from the left is the transmission type code.
A = auto trans
F = 5 speed manual
Y = 6 speed manual
Old Aug 8, 2018 | 09:29 PM
Violator's Avatar
A = auto trans
F = 5 speed manual
Y = 6 speed manual
Thanks for that info. I'll try giving Nissan a try, it does look like there are different part numbers between auto/manual for the dash harness. Maybe I'll get lucky with a member parting out on here or a junkyard that's not more than a CPL hours away. If I'm extra lucky they'll have an i35 too I've decided to go with the gauge cluster for it using the wiring diagram I found for the 02/i35 cluster swap. That cluster looks clean i think I'll have my engine sold soon hopefully I can get this wiring done. I'm set to go back to school and start college in a couple weeks
Violator
Nov 16, 2018 10:24 PM
Violator
Oct 31, 2018 10:57 AM
Redline Maxima
Jun 16, 2010 10:56 PM
