Shifts into highest gear only when trans operating temp is reached
Old Oct 28, 2018 | 08:22 AM
seadonkey79's Avatar
Before my car (specifically the trans) reaches full operating temperature, it will not shift into the highest gear. So I get on the highway, get her up to 60mph, which is usually 2000 rpm, and she revs at about 2200-2300. Usually within a few miles of driving, it'll shift into high gear. This phenomenon is directly related to the outside ambient temperature, which makes me think it's directly related to the transmission operating temperature. During the warm summer months, it sometimes shifts into high right away, and if not right away, usually within about one mile of driving. In the winter though, it can sometimes take five miles or more. It's positively related to the operating temperature of the transmission. This has been happening for years now and I see no other adverse effects occuring due to this issue. Trans doesn't slip at all, fluid is the right color/smell, the only other thing I see affected might be my fuel mileage, due to the higher rpms. I did recently replace the speed sensor due to the other usual issues related to that sensor. Those problems came and went when the sensor was replaced. Thank you!
Last edited by seadonkey79; Oct 30, 2018 at 11:27 AM. Reason: Grammatical Error in my original post
Old Oct 28, 2018 | 11:31 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Originally Posted by seadonkey79
Before my car (specifically the trans) reaches full operating temperature, it will not shift into the highest gear. So I get on the highway, get her up to 60mph, which is usually 2500 rpm, and she revs at about 2700-2800. Usually within a few miles of driving, it'll shift into high gear. This phenomenon is directly related to the outside ambient temperature, which makes me think it's directly related to the transmission operating temperature. During the warm summer months, it sometimes shifts into high right away, and if not right away, usually within about one mile of driving. In the winter though, it can sometimes take five miles or more. It's positively related to the operating temperature of the transmission. This has been happening for years now and I see no other adverse effects occuring due to this issue. Trans doesn't slip at all, fluid is the right color/smell, the only other thing I see affected might be my fuel mileage, due to the higher rpms. I did recently replace the speed sensor due to the other usual issues related to that sensor. Those problems came and went when the sensor was replaced. Thank you!
Incorrect, the TC doesn't lock up until operating temp. That's normal operation.
Old Oct 29, 2018 | 09:10 AM
Thanks for your help? Do you have an idea of what potential issues I'm dealing with here?
Old Oct 29, 2018 | 05:31 PM
Dust N Bones's Avatar
If I'm understanding you correctly, that car won't shift into fourth gear until it's at normal operating temperature, than that's functioning as designed. My 2004 I35 does the same thing & back in the 1990's my parents had a 1989 Maxima that also did that. There are other older threads on here about it & the reasons for it, you might be able to find them with a search.
Old Oct 29, 2018 | 05:46 PM
maxinout93's Avatar
yes that is normal operation especially when it gets colder, ive had about 2 or 3 nissans that did the same thing. Once the transmission is warm, it will shift into the overdrive, or that last gear.
Old Oct 30, 2018 | 11:26 AM
Well I'll be darned. I did not know that. Thank you all who replied. Not the answer I was expecting! Glad to know it's working properly. Seems strange to me though, I've never been in another vehicle that operates that way, to my knowledge. Cheers!
Old Oct 30, 2018 | 08:02 PM
User1's Avatar
Nor have I. I'm no fluid dynamicist, so I can't speak on the effects of ATF or other fluid viscosities or properties or any of that scientifical stuff, but that seems like a bad design. Every single automatic I've ever driven in the past, from Hondas, Chevys, to Mercedes S Classes have shifted through the appropriate gears whether 2 minutes after driving in 25 degree Denver weather or 116 degree Phoenix weather. Your symptoms seem anomalous, and your intuition is speaking to you.
Old Oct 31, 2018 | 08:37 AM
mclasser's Avatar
My I35 was the same when cold. It surprised me at first; much different behavior than my Hondas.
Old Oct 31, 2018 | 02:12 PM
I knew my intuition was sometimes correct. Happy I'm not alone in my thinking! Is it possible that Nissan is the only car manufacturer EVER to be designed this way?
Old Oct 31, 2018 | 06:38 PM
Donkeypunch's Avatar
when your speed sensor was bad did it sorta slip and not shift up from 2nd when hot?
Old Oct 31, 2018 | 11:35 PM
Bad *** Newb
No. Ford and diesels do this.
Old Nov 1, 2018 | 11:44 AM
The speed sensor - I only had problems on really hot days, 90+ weather, where the trans would start slipping into neutral while driving. It also would shift really hard if it shifted at all. I would have to let it cool down before I was able to continue driving. The new speed sensor fixed that. Super easy fix for anyone preparing to do theirs.
Miket2006
Sep 25, 2015 08:51 AM
caddop22
29
May 2, 2013 10:08 PM
Olezhka
27
Apr 30, 2012 11:05 AM
cpuguy06
Mar 8, 2009 06:58 PM
VDOG
Oct 13, 2006 03:41 PM
