Rewire your turn signals so that the "hi" mode is always on?
Anyone know how to do this on a 5thgen?? I have HID Headlights and Foglights.. But I have the Extreme Whites in my 1157 turn signals. The color doesn't match right with my other lights. Anyone know how to re-wire them so that it's always on hi mode? Running dual filaments.. I know you also have to change the amp on the fuse too right??
Re: Rewire your turn signals so that the "hi" mode is always on?
Re: Re: Rewire your turn signals so that the "hi" mode is always on?
Originally posted by ru4real
No, I don't know how, but I haven't really thought of how to do that, because I LIKE HAVING TURN SIGNALS. I have Polarg 1157, and they don't match unless they're blinking. Do you want to rewire them so they're on high, but they blink low when you're signalling?
Very simple and FREE solution...
This solution allows NO UGLY A$$ amber color(Xtreme White color in your case) to be produced UNLESS the blinker is flashing. Simple solution thats been around for awhile. Plus your 1157 bulbs will last MUCH longer, since they are only used as blinkers and not running lamps.
Re: Very simple and FREE solution...
Originally posted by IceY2K1
Remove the bulb, place a piece of electrical tape over one "knub", reinstall, test to make sure you covered the right one, if not, remove and cover the other "knub".
Or I can basically just get like a 21W 1157 and shave off the top nub, put it in backwards and just have the turn signals on all the time when the headlights are on?
Re: Re: Very simple and FREE solution...
SO then they won't be on when the running lights are on? So basically the only time they will be on is when I signal. No need to upgrade fuses or anything right? Woun't shaving off one of the ***** yield the same?
I think this should be the FIRST mod any Maxima owner does, since it's FREE, easy, and looks a lot better at night with just white light on the front of the car.
Originally posted by ToYLeT902
i remember you told me this a long long time ago.. i think i'll finally try it
Or are you lazier than me on the HIDs?
I added it to the "How To" sticky: http://forums.maxima.org/showthread....3&pagenumber=4
I did the "mod" (I have trouble saying that because to me taking 5 min. to put electrical tape over my "nubs" hardly can be justified as a "mod" in my mind) except I have PIAA Platinums all around.
I'll post pics, because I have "wannabe" HID bulbs and ion-lens foglights, but from the front my Max looks like a Lexus (HID-blue headlight with yellow fogs) It looks great without the corners on all of the time!
I would definately recommend this to everyone!
