Why 2 crank position sensors ?
Old May 21, 2019 | 10:11 PM
Cronicjohnson's Avatar
I'm wondering why our cars have 2 crankshaft positioning sensors? Every other car I have owned only has had one.
Please, thanks, live long and prosper.
Old May 21, 2019 | 10:44 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Originally Posted by cronicjohnson
i'm wondering why our cars have 2 crankshaft positioning sensors? Every other car i have owned only has had one.
vvt
Old May 21, 2019 | 11:13 PM
chop_sooie's Avatar
There is only one CRANKshaft position sensor. There are two CAMshaft position sensors (for the reason mentioned above.)
Old May 21, 2019 | 11:33 PM
Slamrod's Avatar
3.0s have two, 3.5s have one. Always worth mentioning which car is being talked about since this subforum effectively shares two generations and things that apply to one car dont always apply to the other.
As for why the 3.0s have two, no idea. Redundancy maybe? Nissan went back to one crank sensor with future iterations as already pointed out, so i guess the reasoning wasnt all too solid in the first place.
Old May 21, 2019 | 11:42 PM
chop_sooie's Avatar
Woops this is correct, my mind just always goes straight to the 3.5 engine when talking about 5th generation simply because that's all I've owned.
Old May 22, 2019 | 10:31 AM
Bad *** Newb
I assumed he meant cam lol
Old May 22, 2019 | 11:26 AM
Turbobink's Avatar
Two purposes:
1. Ignition timing;
2. Tachometer and/or engine speed monitoring.
The function of the crankshaft position sensor (POS) is to allow the engine management system to initiate ignition (spark) at the appropriate time prior to a given piston reaching top-dead-center.
The function of the crankshaft position sensor (REF) is to determine engine speed for the purpose tachometer operation and fuel management.
Old May 25, 2019 | 08:41 PM
Ok great thanks for the replys. Just not something I am used to seeing
baggyrb4
Aug 5, 2016 02:04 PM
johnaschon
Oct 29, 2015 02:43 PM
dnice02
Sep 8, 2014 08:57 AM
rosader
Mar 22, 2010 09:25 AM
maxs4life
Jan 4, 2006 12:24 PM
