Car can’t make up its mind on what it wants to do.
Old Aug 5, 2019 | 04:29 PM
nflfn257's Avatar
So I have a 2003 maxima 6 speed. 230k on the body 80k on motor. First started about a month ago. Was driving right by my house maybe a mile after I left my driveway and the car severely died in power. Almost felt as one of my timing chains snapped, than all of a sudden boom back to normal. About half mile after this same thing then back to normal. Did this in quicker intervals then it just died and won’t start. Walked home and got my father to go tow it. Maybe an hour later. Car didn’t start. He towed me back. Car started in my driveway like nothing happened. Haven’t had a problem until right now. Randomly on the highway about a month later. Car just runs heavy and shut off within five seconds. I have zero codes and no pending codes. I have no idea what it is but it’s so random. I read things about the crankshaft positions sensors could be bad. Everything I read is about cars constantly running like crap when mines just running fine for months the it’s happens again and I’m stuck. What do you guys think?
Old Aug 5, 2019 | 06:37 PM
freezer's Avatar
Check all the grounds.
Primarily:
- the 2 on top of the engine on the timing chain case
- the main battery ground which bolts to the metal coolant passage between the 2 banks
Check harness connections too for loose connections. Sucks that you don't have any codes to narrow things down at all.
Old Aug 6, 2019 | 10:45 AM
Donkeypunch's Avatar
one thing you can try it's like 10 bux at the dealer there's a resister in the harness near the front of the engine
i forget what it's called but some for some people that goes bad.
Old Aug 6, 2019 | 01:58 PM
User1's Avatar
Ignition Condenser.
https://www.nissanpartsdeal.com/part...wiring,,28351M
Do a thorough harness and electrical connection inspection. You say not original motor, so God knows what's going on. Does sound like intermittent electrical failure.
Old Aug 6, 2019 | 10:54 PM
jayfoxx357's Avatar
Similar thing happened to me. Turned out to be electrical
Old Aug 7, 2019 | 07:28 AM
Prophecy99's Avatar
CPS sensors sounds like to me, i had all those symptoms and no codes, it would go away for weeks then show up more frequently
Old Aug 11, 2019 | 05:11 PM
Jsbeeson's Avatar
Mine did something similar last year and I needed a new crankshaft position sensor.
Old Aug 12, 2019 | 07:27 PM
DennisMik's Avatar
MAF is another possibility.
Old Aug 12, 2019 | 08:35 PM
Child_uv_KoRn's Avatar
Bad *** Newb
sounds like cam/crank sensor
Old Aug 13, 2019 | 03:26 PM
theoman3's Avatar
yes....same symptoms for bad MAF, but scanner should usually show P0100
gldmaxx98
Jul 10, 2015 08:48 AM
cvsmaxima
53
Mar 6, 2009 04:47 AM
btbrown
Nov 12, 2008 09:01 AM
MadMaxSE-L
Sep 14, 2007 05:18 PM
one2fastse1
Apr 7, 2003 07:46 AM
