2001 Max loses power...NEED HELP
Old Oct 4, 2019 | 11:27 PM
vebong's Avatar
I was at an drive thru ATM earlier tonight, and my car suddenly lost power; not sure why; luckily I was only 2 miles from home so was able to drag it home
Symptoms include intermittent flashing all the lights on dash especially when I'm at a stop light with car jerking a little
Had to turn off the radio and all lights in order to get home. Luckily, there was little traffic at 1 am in the morning and I was able to catch all green lights till I got home
When I got home, and parked, lights started flashing again; had no luck rolling up automatic windows
After 30 minutes hiatus, tried to start car and it would not start....getting a clicking sound although lights come on the dash
Wondering if it is a faulty alternator, and not sure how Im going to get her to the shop
Old Oct 5, 2019 | 02:57 AM
Theslaking's Avatar
Charge the battery. These car will drive several miles on just a battery. Enough to get you to the shop. First check and make sure your battery and alternator connections are tight. Power and ground.
Old Oct 5, 2019 | 11:16 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Sounds like alternator is ****ed and battery is drained. If you jump start it and it dies after removing cables, then there ya go. Even if it stays running check the voltage. If it's not 14-15V, then it's bad (b/c 13s will drop even lower with load, which you can test just by turning on all lights/radio).
Old Oct 5, 2019 | 12:09 PM
DougR's Avatar
Recharge battery, check connections, clean dirty connections and verify a bad alternator by checking output voltage per other posts. I had a similar situation and had my alternator rebuilt by a local shop. I don't trust alternators from box stores. Shop carefully, NAPA might be OK. Search for other posts on alternator quality if you need one.
Old Oct 5, 2019 | 04:56 PM
User1's Avatar
Ebay.
Old Oct 5, 2019 | 06:28 PM
vebong's Avatar
Thanks for all the responses....will check and attempt to recharge battery and alternator on Monday; in the meantime, it'll just sit there
Garrettz459
Jan 4, 2015 01:44 AM
zoutv
58
Sep 25, 2009 10:19 AM
paulsfds
26
Dec 7, 2005 01:15 PM
jasba
22
Jun 1, 2005 07:00 AM
Mad-Marcus
Sep 9, 2004 09:09 AM
