This don't seem quite right
Old Jan 8, 2020 | 04:30 PM
cdoublejj's Avatar
Looks like it's touching maybe that's what all the racket is?
Old Jan 8, 2020 | 04:39 PM
slvr2KSE5's Avatar
Can't tell. You're there. You can look it over and see contact marks.
Old Jan 8, 2020 | 08:05 PM
cdoublejj's Avatar
How close are the factory end links?
Old Jan 8, 2020 | 08:12 PM
slvr2KSE5's Avatar
I'll have to get you a better pic but I see nothing unusual about your picture.
I included a very zoomed in and dark picture of mine from my header install.
Old Jan 9, 2020 | 01:01 AM
LA02MAX's Avatar
I've never liked those MOOG endlinks... always had issues getting the bolts tightened or loosened. Anyway, the endlink is installed into a bracket with a hole on the control arm. There's very little movement possible unless that hole on the control arm is wallowed out. Even with the endlink threads sitting in the lowest part of that hole, there shouldn't be any contact. I can't tell from your photo, but it doesn't appear to be contacting the control arm - it's just close.
Old Jan 9, 2020 | 06:17 AM
pastaben's Avatar
Check the other related bushings - sway bar bushings, control arm ball joint, end link joints. Use a pry bar and see if there's movement.
Old Jan 9, 2020 | 10:49 AM
cdoublejj's Avatar
They are waaayy bigger than the stock ones, if there is a gap it's few thousands. I think the hole was/is slotted. It was a cheap Chinese kit with a arms and end links and ball joints etc etc all with greaseerts, will try to get it on a rack tonight
eminemdpc
62
Aug 13, 2009 05:36 PM
LudeAEM
42
Feb 21, 2005 09:14 PM
