Shifting problem 2002 Maxima (96,000 miles)
Old Feb 14, 2020 | 11:44 PM
ericyung's Avatar
There is some resistance when I shift from Neutral to Drive. I have to force it and usually I would end up at '2". Even if I am lucky enough to get to 'D" I found that the engagement is rather "shallow". Any idea what is wrong?
Thank you.
Old Feb 15, 2020 | 12:52 AM
User1's Avatar
Cable and/or linkage is binding. Tear it apart and check it out.
Old Feb 15, 2020 | 01:53 PM
pastaben's Avatar
Check the PNP switch operation. Park neutral switch is in engine bay, on transmission, behind driver's headlight. See if nut is on okay. Make sure lever moves smoothly through the gears.
SR20DEN
Sep 4, 2010 11:21 PM
MaxDriver98
Dec 28, 2001 12:34 AM
bioyuki
May 20, 2001 03:32 PM
