Won't start
Old Oct 5, 2020 | 10:17 PM
Crashdawg's Avatar
Won't start
Hello all. I have a question that may have a million answers. I recently obtained a 2000 maxima from a friend. I picked the car up and brought it home. It sat a couple months and now I finally got the title straight. I tried to start today and battery was bad so I put a new one in. Now the car cranks like it should but won't even try and start. It has almost a full tank of gas. Where would you guys start looking. It is my first Nissan. Thanks for any advice.. CRASH.
Old Oct 6, 2020 | 06:27 AM
Costee's Avatar
Does the security light blink when the car is switched off? Is the security light on or off when the ignition is turned ON?
Old Oct 6, 2020 | 05:44 PM
maxiiiboy's Avatar
This decision table may help: https://drive.google.com/file/d/1iOG...mKlsHwSf5/view
Old Oct 7, 2020 | 09:58 AM
Crashdawg's Avatar
when key is inserted the light flashes slow. if i turn key to run position it is off
Old Oct 7, 2020 | 10:29 AM
Costee's Avatar
That rules out NATS in a way. Try the checklist suggested in the link provided by maxiiiboy.
Old Oct 8, 2020 | 07:56 PM
Bk2's Avatar
Bk2
If the fuel pump clicks when you turn the key to second position it is working, with the battery being new and it’s cranking then it’s not a battery or starter problem. I’d check the alternator. Sometimes they go bad when the car sits as well. Had it with my 01 mustang gt I changed the bat and alternator then car sat for two years battery was fine with a jump but alternator was toast.
Old Oct 9, 2020 | 11:50 AM
Crashdawg's Avatar
motor turns over like there is no problem. Just won't start.
Old Oct 9, 2020 | 01:05 PM
maxiiiboy's Avatar
Well, that's a clear indication of what's wrong. Your problem is one/more of the following:
  • No Spark. Pull a spark plug and verify it's firing when you crank the engine. If not firing, check the fuses and coils.
  • No Fuel. Is the fuel pump running? ... It should run for a couple of seconds the moment you turn the ignition to ON. The fuel pump is under the back seat. Have a helper check the voltage on the lead. If the fuel pump is not running, there are three possible culprits: The pump itself or the associated relay, the FP fuse (see below), or the CPS (see the next bullet).
  • ECU gets no feedback from CPS. The ECU relies on the feedback from the CPS to confirm that the engine is firing. If no feedback, it shuts off the injectors to prevent flooding the engine.
I suggest you start with the easy stuff first. Check all fuses, and the following two in particular: a) The ENG CONT1 fuse in the fuse box by the battery, and b) The fuel pump and injector fuse (#29 in the fuse blox by your left hand).
Old Oct 9, 2020 | 09:49 PM
User1's Avatar
Fuse.
Old Oct 28, 2020 | 01:24 PM
Crashdawg's Avatar
been working way too much so i had to wait on the car. i did get to run a scan and it says crank position senor.. anyone here ever changed one of them?
Old Oct 29, 2020 | 09:50 AM
rodent_infested_03's Avatar
Yep, crankshaft and the camshaft sensors can cause that. Pretty common problem. Use the Hitachi sensors. Be real careful taking off the connector. Its not the usual squeeze type.
Old Oct 29, 2020 | 12:22 PM
Crashdawg's Avatar
where is this located on these cars.
Old Oct 30, 2020 | 04:16 AM
Prophecy99's Avatar
look it up, its posted around here, they are on the engine
willard00
May 30, 2006 09:31 PM
blueice
Apr 8, 2006 06:24 PM
