Got My Coolant Flushed. Now My Radiator Fans Won’t Turn Off.
Old Nov 12, 2020 | 08:05 PM
2DAMAX-4DSC's Avatar
Had My Coolant Flushed. Now My Radiator Fans Won’t Turn Off.
2002 Nissan Maxima GLE with factory nav and integrated climate controls.
Had a local shop flush the coolant, replace the upper and lower radiator hoses and swap out the thermostat (and housing) one or two Fridays ago. After filling the system with fresh coolant, the shop owner said he had issues sorting out the cooling system: The fans were turning on when they weren’t needed and after about five to ten minutes of driving.
He initially thought he wasn’t fully purging the system of air, which was leading to the radiator fans turning on, but he eventually ruled that out as he spent several hours trying to diagnose and purge the system to no avail. The fans turn on after about five minutes of light driving and before the system reaches the adequate temperature required for them to activate. He emphasized that the car was NOT overheating and that the fans were turning on BEFORE they should have, which I believe he said is 205 or 215 degrees Fahrenheit. Just to clarify, this is with the AC system OFF and after purging the system with the heater at full blast.
He wasn’t able to figure out what was causing the problem and ended up refunding me for the service (minus the coolant cost) since he left me with an issue that wasn’t there before. Yay! 😑 At least I’m not overheating, but the car sounds pretty nasty at stop lights, etc. and I’d really like to fix whatever is causing the fans to stay on.
The mad scientist next door thought the shop may not have purged the system correctly so he tried purging it himself in his driveway, but the fans turned on again the next morning after about five mins of driving.
I narrowed down the problem to possibly being a bad relay so I replaced the relay in the RAD FAN 1 slot hoping that it would solve the issue. It didn’t. I read in another thread here that the RAD FAN 1 relay controlled the speed of both fans, but further reading of that thread told me that this only applied to 4th gen Maximas. Can anyone clarify? And is it possible that the problem I’m having is being caused by bad fan motors instead or an improperly installed or faulty thermostat?
I have a suspicion that it may be the coolant temperature sensor, but I’ve also read that this will usually lead to overheating, not overcooling, and I don’t want to keep throwing relays and sensors at the car without knowing what exactly is wrong or broken. Anyone here have any ideas? I’m about fresh out. 🍄
This post leads me to believe it’s a bad thermostat:
https://maxima.org/forums/5th-genera...an-always.html
Might have the neighbor throw in a fresh one from Autozone instead.
Old Nov 12, 2020 | 09:31 PM
Incorrectly installed thermostat or bad thermostat
Old Nov 12, 2020 | 09:34 PM
Excellent. I’ll be pulling out the new one to have it replaced under warranty. Thx, Wiz. 🍄
Old Nov 12, 2020 | 11:05 PM
I wouldn't use an Autozone thermostat. Go with OEM.
Old Nov 12, 2020 | 11:07 PM
And since you are going to have to re-burp the system of air, either have the front end on ramps or have it jacked up in the front to ensure it's purged of air properly.
Old Nov 13, 2020 | 07:38 AM
2k2albatross's Avatar
Did the "mad scientist" have the front of the car on an incline as mentioned by The Wizard? I have the Lisle Funnel which I have used on my Maxima and it worked great with the car on an incline.
Old Nov 13, 2020 | 10:03 AM
Yes, he’s a professional, my guy. Don’t ever disrespect the mad scientist like that.
Old Nov 13, 2020 | 10:04 PM
User1's Avatar
Kinda hard to fck up a thermostat install but ok. Let us know how it goes.
Old Nov 14, 2020 | 12:23 AM
It's actually quit easy to screw up a thermostat install. Install it upside down and the air bleeder thingy won't function properly.
Old Nov 14, 2020 | 12:34 AM
User1's Avatar
No, it's not, it is literally impossible to f*ck it up. It is built into an assembly with the coolant neck.
https://www.nissanpartsdeal.com/part...200-8j100.html
Old Nov 14, 2020 | 01:41 AM
If you buy an Autozone thermostat and use the OEM housing, it can be installed incorrectly (same goes for OEM thermostat).
Old Nov 14, 2020 | 01:42 AM
Been a while since I've purchased an OEM thermostat, but IIRC, you can buy just the OEM thermostat by itself w/o the housing.
Old Nov 14, 2020 | 01:48 AM
User1's Avatar
If you buy an Autozone thermostat and use the OEM housing, it can be installed incorrectly.
Are you on drugs? It is an assembly, a housing, built-in, with a bolt pattern that cannot be incorrectly installed, there is no possibility of purchasing a new thermostat in any other form, no matter where it is purchased. OP has an electrical problem.
User1's Avatar
No. Lol
Old Nov 14, 2020 | 01:55 AM
I don't think we're talking apples to apples here.....You can buy any aftermarket thermostat and install it into the OEM housing. Look at the picture you posted. See those two screws? The thermostat comes out.
Why would the OP have an electrical problem? He didn't have these issues before the work was done, so common sense should tell us his new issue is most likely related to the recent work that was done.
Old Nov 14, 2020 | 01:59 AM
User1's Avatar
Ummmm....yes. You're wrong dude.
No way dude, you're still drunk from last night and think you're modding the Lexus forum. I'll wait for your link to the thermostat only, with no housing.
Go to bed lol. Then when you wake up, tell IB to add dark mode to this place already will ya? Sheesh
Old Nov 14, 2020 | 02:00 AM
Just realized OP has a 2002 so my info may be bad. I thought he had a 2001. All my experience is with 95 through 2001 Maximas. The picture you posted I believe is for the 95-2001 though.
Old Nov 14, 2020 | 02:03 AM
No darkmode.
Old Nov 14, 2020 | 02:06 AM
User1's Avatar
It is not, it is from a 2002, but that's ok. You had a long night, I understand lol
Old Nov 14, 2020 | 02:18 AM
User1's Avatar
"Common sense" would tell me he is fail-safe-ing for some reason. But I need more info. Too much focus on non-issues like purging and not enough focus on whatever that grease monkey mechanic jacked up.
A note on "purging"; It's not necessary. Fill up the radiator, start the engine, use your radiator funnel, rev it a few times til no more bubbles come out, and you're done. No need for ramps, there's no special magic or valve that opens when you turn the heater on, so you don't need to do that either, just fill it up, fill up the overflow tank, and drive the damn thing. None of that crap is even listed in the FSM for bleeding the coolant system. In 20 miles your radiator cap will have done it's job and purged air and/or opened to suck in coolant and the system will be in equilibrium.
Make this a sticky or something.
Old Nov 14, 2020 | 02:20 AM
Like I said, I have no experience with the VQ35 engine, but that picture looks just like the VQ30 thermostat housing. I believe you that it's a VQ35 thermostat housing. Appearance wise, they are awfully similar.
If you undo the two screws, the thermostat can be removed, correct? What if the mechanic bought brand X thermostat w/housing, but used Brand X thermostat and swapped it into the OEM housing? Certainly that is a possibility, correct? And therefore, the thermostat could have been installed upside down?
And I suppose if the assembly guy at the assembly plant was hungover or having a bad day, the thermostat could have been installed upside down. Or maybe it's simply just faulty. Sometimes brand new parts are bad right of the box.
And I went and checked for ****s and giggles, you can indeed buy a thermostat separately for the 95-01 Maxima. I thought I was going crazy there for a second. LOL
Old Nov 14, 2020 | 02:23 AM
User1's Avatar
How do you mod a forum focused on the VQ35 for 20 years and not be familiar with it
Old Nov 14, 2020 | 02:27 AM
Well, in the 4th gen world, a lot of people have trouble purging air for some reason or another. Jacking the front of the car up seems to do the trick.
And yes, it would be nice to know exactly what the mechanic did do or touched. All we can do is visualize what he should have done and touched and retrace said steps.
Old Nov 14, 2020 | 02:29 AM
User1's Avatar
Well, in the 4th gen world, a lot of people have trouble...
You could have just stopped there lol
Old Nov 14, 2020 | 02:32 AM
Who said I'm a moderator specifically for the 5th gen forum? I post across all generations and try to help others when possible. I also haven't been a moderator for 20 years...not even close. Now who's on drugs? LOL. Go to sleep son.
Old Nov 14, 2020 | 02:39 AM
User1's Avatar
I'm just giving you a hard time like I always do, man
Will wait for OP to elaborate on his electrical situation and history...
Old Nov 14, 2020 | 12:07 PM
Electrical system hasn’t been touched.
Car was running incredibly cool since the day I bought it. Still is.
Should have clarified in the OP, it was a Murray Plus OE thermostat AND thermostat housing from Oreilly.
Shop recommended I swap the thermostat. Something in the back of my mind was telling me I shouldn’t, since the entire cooling system was working just fine before which means the thermostat was presumably doing it’s job. Should have listened.
Old Nov 14, 2020 | 01:30 PM
saig's Avatar
I would check thermostat opening temperature (F) since murray brand has so many variants: 160, 180, 185, 187, 195, 203.
If OP got wrong unit, he needs to reimburse the shop service since he provided all the parts.
Old Nov 14, 2020 | 02:25 PM
User1's Avatar
Good call, did not know so many temps were available for aftermarket T-stats. Not sure why there would be, but ok. Why I stick to OEM with critical components.
T-stat specs will accompany whatever model number variant OP bought, if that's the case. If there's a 160 in it, then yeah, fans gonna run a lot Lol
Old Nov 14, 2020 | 06:26 PM
saig's Avatar
I think OP may've had 203F unit. It opens late. It's for those who want to get heat quickly and is more suitable for frequent short trips.
I'd pick OEM unit too for convenience, peace of minds, no price difference.
Old Nov 14, 2020 | 06:32 PM
User1's Avatar
Nope, 203 is correct. Aluminum blocks like a specific temp, and the engineers of the all-aluminum VQ35 like it to be around 200. To my knowledge, you don't get to pick your T-stat temp parameters for VQ stats. I am not aware of any options such as you suggested, even with aftermarket.
Old Nov 14, 2020 | 08:13 PM
User1's Avatar
I finally had a chance to look around online. 180 seems to be the common value for aftermarket T-stats, and is inline with the FSM opening temp. I couldn't find any other temp values for T-stats from AutoZone or other branded names.
https://www.oreillyauto.com/shop/b/c.../nissan/maxima
So I'm gonna take T-stat off the table. I'm back to thinking electrical issue. I'll get back to this in a bit.
Old Nov 14, 2020 | 08:18 PM
User1's Avatar
Going to post this as a reference until I get back. Again, all my references are sourced from my 2003 SE FSM. 5th gen FSM's will all read the same. This is the definitive guide to proper fan operation.
Old Nov 18, 2020 | 04:54 PM
User1's Avatar
Any progress on this, or do we still need to fry some brain cells? Those ain't cheap, ya know.
Old Nov 18, 2020 | 09:25 PM
Child_uv_KoRn's Avatar
Bad *** Newb
I got three bad motorad t-stats in a row for RWD VQs. They wouldn't open until 212 despite all being 170-180 spec. I gave up, they don't work and are what you buy under any brand name.
OEM is the easiest option, but I used an inline housing on the upper hose on G35. Problem solved and it opens/bleeds instantly!
Check the coolant temp. The fans are working fine.
Old Nov 22, 2020 | 06:04 PM
Got an OEM housing and thermostat in the mail. Should be throwing it on tomorrow first thing in the morning. I’ll report back post-swap.
andi398
Apr 13, 2012 08:37 PM
cspangg
Jul 31, 2011 05:39 AM
jrflores
32
Nov 10, 2009 02:08 PM
nissanmax97
Feb 18, 2009 03:19 PM
Kbuitre
Jul 20, 2005 10:23 PM
