2001 Maxima Bank 2 pre cat
Old Dec 24, 2020 | 02:25 PM
jjvbbvjj's Avatar
Any tricks to getting the bank 1 (front) pre cat to drop out? Got all 8 bolts out and it is loose. Won't drop down because of the flange that inserts from the rear and won't move back and forth because of the two studs on the top side. Don't want to have to take the entire exhaust to the rear loose and don't want to pry too much to separate them. Thanks.
Old Dec 24, 2020 | 03:31 PM
Reality sucks's Avatar
loosen the bolts holding that manifold On, they can be studded to, but some come out bolt and stud, that may give you enough room to lift it up and twist it out. providing the cooling fans are out of the way,
Old Dec 24, 2020 | 04:34 PM
User1's Avatar
You're almost there, drop the Y pipe.
Old Dec 25, 2020 | 06:07 AM
Rust.. IF your not equipped to drill out holes, its much easier to loosen the manifold. Not my choice either, but it has worked in cases where the bolts are just gone on the y pipe.
rubicon03
Mar 31, 2012 09:06 AM
036mtmax
253
Feb 9, 2012 11:01 AM
XFactor27
Sep 19, 2011 06:33 PM
Amave
Dec 29, 2010 01:16 PM
STyLeZ4o1
Jul 4, 2006 05:03 PM
