Fuel Tuning
Old Jan 9, 2021 | 08:32 PM
User1's Avatar
Fuel Tuning
I want to add +15% fuel from 1-4000rpm and +20% from 4001-7000rpm.
That's it.
Is this possible? Stock ECU.
Old Jan 10, 2021 | 04:19 AM
95naSTA's Avatar
With RomRaider, yes its possible.
https://maxima.org/forums/5th-genera...adventure.html
Old Jan 10, 2021 | 04:36 AM
User1's Avatar
I was there for that thread. I don't recall the process of adjusting fuel. The thread was mostly theory and no instruction on how to use the program. Do I just install it and start playing with it? If the software is intuitive enough I'm sure I'd be able to figure it out.
Old Jan 11, 2021 | 04:39 AM
95naSTA's Avatar
It seemed like you wanted a yes or no answer.
The easiest way to do what you want is to adjust the injection k factor by 15%, assuming the software has one, then adjust the MAF table from there for the other 5% where you actually need it.
Old Jan 11, 2021 | 05:08 AM
User1's Avatar
Poor wording on my part, sorry about that. So my goal here is to address the still-existing high-RPM knock that I've been fighting since the swap. I've done everything I can to this point short of a tune, which is hard for me to schedule as my only options are Darren at Nisformance or Moncef at Admin, and I'm in Tampa. So I don't want a tune, I don't want dyno time, I don't want to install an AFR system, I just want to add fuel at the top end.
I'll put RomRaider on my laptop and start familiarizing myself with it. I'll get back to this thread soon, have a few things to get done today.
Thanks for responding.
Old Jan 14, 2021 | 05:27 PM
freezer's Avatar
Just add 20% to K factor and BFS (MTP100). ECU will pull fuel if you're too rich in the lower RPMs
Old Jan 14, 2021 | 05:42 PM
User1's Avatar
Wish I knew all along it was that simple. I still haven't had a chance to plug the laptop into the car or even open the program. I have a couple ECU's in case I brick one. I'll get on this on the weekend at the latest. Pulled some extra shifts. Thanks, guys.
Old Jan 16, 2021 | 09:12 PM
User1's Avatar
Downloaded EcuFlash. EcuFlash definitions from RomRaider link are Subaru and Mitsu only. What are you using for the Maxima?
Old Jan 16, 2021 | 09:16 PM
User1's Avatar
I'll just follow this guide:
http://www.romraider.com/forum/viewt...p?f=64&t=14867
I'm off tomorrow. I'll report back tomorrow eve after I add fuel and WOT test runs.
Old Jan 16, 2021 | 10:19 PM
freezer's Avatar
Yep, and link to defs found here: https://www.romraider.com/forum/view...p?f=64&t=13325
Old Jan 17, 2021 | 02:36 AM
User1's Avatar
Got nothing when I entered my VIN
https://nissan.epc-data.com/
Stuck til I can figure out my ECU ID
Old Jan 17, 2021 | 07:36 AM
freezer's Avatar
You don't need your VIN. Just run nisprog and connect to your ECU. It will tell you your ECUID
Old Jan 17, 2021 | 10:13 AM
User1's Avatar
There's no .exe in the nisprog master
Old Jan 17, 2021 | 10:19 AM
User1's Avatar
Slamrod never explained in his thread what he did.
Old Jan 17, 2021 | 10:29 AM
User1's Avatar
Nevermind, sorry. Used the same broken link Slamrod did. Hold please...
Old Jan 17, 2021 | 10:41 AM
User1's Avatar
Ok got my ECUID. 6Y310.
Working on the dump. Hold please...
Old Jan 17, 2021 | 10:52 AM
User1's Avatar
Stuck. Can't figure out what my FID IC is.
Old Jan 17, 2021 | 12:36 PM
freezer's Avatar
What do you need FID IC for? You can just modify 6y314 and flash it over 6y310.
Old Jan 17, 2021 | 05:40 PM
User1's Avatar
Need FID IC to write the kernel and the nisprog .ini
Old Jan 17, 2021 | 07:41 PM
freezer's Avatar
Your ECU architechure is 7055_35, that's the kernel you'll need to run. So once you've connected and you have the kernel saved in the same directory as you are running nisprog from...
setdev 1
runkernel npk_7055_35.bin
flrom MYNEWROM.bin
Old Jan 18, 2021 | 03:34 AM
User1's Avatar
Right on, thanks. Thought I needed to pull by base image before I flashed it. Still putting this all together. The nisprog I had ran fine, I used several commands while connected to the car. That's how I got my ECUID. What "keys" did I need? I'll work on this when the sun comes up.
Old Jan 18, 2021 | 05:57 AM
User1's Avatar
Do I have to convert the 6Y314.xml to .bin or something? I added 6Y314.xml from the defs master into RomRaider. Didn't make sense because I thought it wanted binary files but I added anyway and of course it can't be found.
Old Jan 18, 2021 | 03:08 PM
freezer's Avatar
No! Just download a stock 6y314 dump from RR forum.
6y314 is an update of 6y310. There's a TSB out for it. Supposed to improve MAF, reduce a transient hesitation issue IIRC. Always best to grab all the factory fixes you can.
I dunno the condition of your fuel pump, but I got a 15% fuel bump when I replaced my failed stock pump with a DW100.
Old Jan 20, 2021 | 04:07 PM
User1's Avatar
Gave it a shot, couldn't figure it out. I'm done with this. Thanks for the help though, guys.
Old Jan 20, 2021 | 05:38 PM
freezer's Avatar
Ha! This from the guy who spent his much time on his BBK?
I don't know what part you're having trouble with, but if you've managed to connect with nisprog you're ahead of 90% of the crowd. I'm already set up to do this, but your scope of work would take me 5 minutes start to finish.
Old Jan 20, 2021 | 05:48 PM
User1's Avatar
nisprog, code, scripts, COM issues, none of that is a problem for me. I need a .bin that doesn't exist. I have yet to find, or even open a .bin, (any .bin at all) with romraider. If it's that ridiculously retarded of a process just to obtain and OPEN an ECU base image, then it'll be nothing but problems, it's faulty and I'm not interested. I'm not even wasting anymore time on this. Got a BBK to finish.
Old Jan 20, 2021 | 05:50 PM
User1's Avatar
Front and rear BBK is almost done, btw. Just need to get two more brackets built. Not a dead project just back burner for a few.
Old Jan 20, 2021 | 06:20 PM
User1's Avatar
I gave it one last stab and took the time to complete the painfully arduous process of registering for RomRaider.com and downloaded 6Y314. As a non-member, you do not have access to view or download posted files. So tired of signing up for ****.
I'll check back someday after I have the time to learn the program enough to understand and decrypt post #6
Old Jan 20, 2021 | 06:43 PM
User1's Avatar
Am I really just adjusting these values? So +20% for BFS =23.24, and +20% for K Value =33,110.4?
Old Jan 20, 2021 | 07:10 PM
User1's Avatar
It that's the case, I'm ready to flash. kernel is in the same disk location as nisprog.
#This is just an example .ini file to show some of the possible commands.
set
interface dumb
#Customize this to your hardware
port \\.\COM3
#This should always be OK
dumbopts 0x48
# No need to touch these unless you know what they are
l2protocol iso14230
initmode fast
testerid 0xfc
destaddr 0x10
addrtype phys
up
setdev 1
flrom C:\Users\JQual\Downloads\ECU ROMs\6y314_edited.bin
Old Jan 20, 2021 | 07:37 PM
User1's Avatar
Connected to car, no fans, no worries, all was good. Did not flash yet. At work and don't want to risk needing an Uber home in the morning. While we're at it, may as well up the rev limiter to 7,200. How do I do this
Old Jan 20, 2021 | 07:44 PM
User1's Avatar
Nevermind I figured it out. Do I need to adjust Rev limiter "Reverse" values for anything? Ok, here's my final edit:
Old Jan 20, 2021 | 07:59 PM
freezer's Avatar
No, don't need to do reverse limiter. And you've got the fuel K and mTP100 adjusted properly. When flashing over 6y314 it'll change almost all of the blocks, so a reflash will take a couple minutes. I'd also suggest doing it at home, it would suck to have a brick at work. Especially the first time around.
I quickly forget you have to register at RR to download stuff, I could have uploaded a copy but I was responding from my phone.
Old Jan 20, 2021 | 08:07 PM
User1's Avatar
Will flash first thing in the morning when I get home. Thanks again.
Old Jan 21, 2021 | 09:35 AM
User1's Avatar
No cigar. Your lines in post #20 are different than stated in the RR tutorial. Tried running the kernel line alone to see if it would grab the rom, didn't work. Tried adding the rom address after the kernel command and still no cigar.
Old Jan 21, 2021 | 09:49 AM
User1's Avatar
Woops, wrong directory, let me try that again. Hold please.
Old Jan 21, 2021 | 10:08 AM
User1's Avatar
Says "cannot open" kernel filepath
Old Jan 21, 2021 | 10:17 AM
freezer's Avatar
Can't have spaces in the directory or file names
Old Jan 21, 2021 | 10:35 AM
User1's Avatar
Where are you seeing spaces
Old Jan 21, 2021 | 10:49 AM
freezer's Avatar
Saw it in the earlier post. "ECU ROMs"
setdev 1
runkernel "your_directory"\npk_SH7055_35.bin (the SH was missing)
flrom "your_directory"\6y314_edited.bin
I put nisprog in a root directory on c:, eg C:\NISPROG to save typing out long directories. Put nisprog, the .ini, the kernel you need and the rom you want to flash in there.
