Bosch or Denso Downstream o2 sensor?
Wow, I watched a youtube video on it. The guy ended up cutting the wire from the old o2 sensor to remove it, and took several minutes just to remove the front clip from the engine bay. From the looks, you need to push in with a flat head while pulling out at the same time. Is there a special tool I need? the part number is 15225
The only tool youll need is an o2 sensor socket. You could use a wrench, but the socket prevents stripping. Soak the sensor for a day or two and its no big deal. Also for the plug, be very careful with it bc they will break like a dry noodle, ask me how i know. But yes, pry down with flat head then pull away with your hand
Dont use WD40, its not a penetrating fluid. Use any sort of penetrating fluid. For the sensor plug theres not much you can do. The new one should come with the plug, but if youre really worried about breaking it, spray some spray silicone on it and let it sit for a couple days, might help it absorb some moisture. I think one or two of mine broke and i just zip tied them together
