Coolant leak near throttle body
Old Aug 9, 2021 | 12:14 PM
hithesh's Avatar
My waterpump went bad, I replaced it and I was still losing a small amount (12oz per 30miles) coolant. I thought it was the radiator but decided to do the pressure test.
Got a loaner pressure test kit from orielly and saw coolant pissing from just below the throttle body.
It's form a small hose about 8inches or so. Could not find the part # for this.
After searching, found this thread, but couldn't get part #.
https://maxima.org/forums/4th-genera...-firewall.html
Any write ups or videos on how to replace this would be great.
Old Aug 9, 2021 | 03:20 PM
RA030726's Avatar
I'm nutty for Nissans
Get hose by the foot at your local parts store. I'd guess it's 5/16" but measure yourself to be safe.
Old Aug 10, 2021 | 11:20 AM
uptownsamcv's Avatar
make sure to change the clamps too, those spring clamps lose tension after a while. I was taught to never reuse them once taken off.
Old Aug 12, 2021 | 06:57 PM
User1's Avatar
Depending on where you live, you don't even need that hose. Cap it unless you're way up north and freeze a lot.
Old Aug 13, 2021 | 12:39 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Still don't need it. Delete PCV (or good catch can), then there's zero risk.
Bypass it, OP, or IACV will take out ECU.
nitink
Oct 16, 2006 10:14 PM
aznsap
Jun 15, 2006 01:37 PM
R92max
Jun 3, 2006 09:53 AM
DougyD19
23
Oct 22, 2004 11:23 AM
woosh
Oct 15, 2004 08:31 AM
