P1800 Code - Broken Wiring Harness 😬
Old Aug 1, 2021 | 01:40 AM
I35GEEK's Avatar
When I was fixing a coil pack misfire at cylinder 5, I had to remove the intake manifold and disconnect the vias control solenoid valve.
The misfire is now fixed. But when I went to reconnect the vias control solenoid valve, I heard the plastic wiring harness snap and the 2 wires popped out of the plug. ☹️ P1800 code was generated. I shoved the wires back into the plastic connector and code P1800 is now gone. It is only a temporary solution because the 2 wires are loose in the plug.
I am looking at getting a new connector for the vias control solenoid valve. It has 2 wires. I can’t seem to find the part anywhere not at rockauto or Amazon. Does anyone know the part # for this connector and where I can buy one?
eBay has a couple of used ones but not sure if they fit. I may have to get one from the stealership. 🤑
Old Aug 2, 2021 | 02:17 PM
nestorlugo's Avatar
Could go to the salvage yard and cut a pigtail then solder it to your harness or just de pin the connector.
Old Aug 2, 2021 | 08:42 PM
I35GEEK's Avatar
I took the actual connector out of my car and compared it to connectors on eBay. I was able to find a perfect fit - used.
Old Aug 14, 2021 | 01:57 AM
I35GEEK's Avatar
Well. eBay connector arrived but it did not fit. I called dealer to see if I can buy it new. The parts department told me to try a Pull-A-Part place.
Wow. I am amazed at how organized these places are. They had 4 Infiniti I35 on their lot. It was kinda fun going there and pulling all the missing parts for my car. I got my connector, vacuum hoses, trunk rubber bumper etc. Highly recommended place to get used car parts - cheap.
https://www.pullapart.com/inventory/...ars=-1#results
Old Aug 14, 2021 | 05:45 PM
User1's Avatar
I have four LKQ yards here in Tampa. Pulled lots of stuff for my Maxima. I love going to the yard and seeing what kind of goodies I can find.
That reminds me, I need a new center dash vent, guess I'll have to make a trip to the yard Monday!
Old Aug 14, 2021 | 06:46 PM
I35GEEK's Avatar
Yes. I can’t believe that I found a new hobby too going to the junk yard to pull parts for my car! It is an adventure indeed.
Now that my I35 is pushing almost 20 years old, the junk yard may be my last source for parts. My I35 has 175,000 miles. I like to get it to over 200,000 if I can.
nismopc
Mar 22, 2020 05:20 PM
MAXimumWarp
Jul 12, 2012 03:01 PM
ruckus1027
Feb 27, 2009 07:57 PM
alleydawg6
Aug 10, 2006 01:44 PM
