Throttle Body plate/gasket mystery
Old Nov 30, 2021 | 03:02 PM
Legionnaire1856's Avatar
Hey guys,
I just got my car back together after doing the rear valve cover gasket and I replaced the throttle body gasket when I put it back together. It was the O-Ring type gasket that pressed into the plastic intake manifold, then the black plate goes onto that and then the throttle body goes up against the black plate.
Well there is no gasket between the black plate and throttle body, it's just metal to metal. So why have a gasket to seal the black plate to the manifold and then none to seal the other side of the black plate to the throttle body? I can't find the black plate anywhere in the diagrams...it's like it's not even supposed to be there. It's driving me nuts, I feel like either the plate shouldn't be there or there should be a second gasket.
Does anybody know about this? Thank you
Old Nov 30, 2021 | 06:25 PM
maximanut2001's Avatar
I just put mine back together today. I probably did it wrong. I went:
1. New o-ring like gasket pressed into intake manifold
2. Black plate
3. Flat gasket between black plate and throttle body.
I got the intake manifold gasket "kit" from OReilly's (Fel-Pro I think). I didn't do the lower intake gaskets because I didn't disassemble the top of the motor that far. I also did not replace the other gasket in the kit (IACV?). I just put them away for later if that ever happens.
Edit to add: I think I did it correctly according to the pic:
Old Nov 30, 2021 | 06:59 PM
Reality sucks's Avatar
16293MA is what you are Missing the Other Gasket between the Plate and TB.
Old Nov 30, 2021 | 08:30 PM
One other thing I wanted to add.....I remember when i took my throttle body and the black plate off, there was NOT a flat gasket in between there. As far as I know, this is the first time coming off as I am the original owner of this 2001 Maxima. I only put the flat gasket on in between there because it was in the kit.
Perhaps someone knows if the cars did not originally have a gasket from the factory in between TB and black plate.
Old Dec 1, 2021 | 06:05 AM
2. Black plate
Well shoot, now I'm even more confused. I had typed my VIN number in at Nissan Parts Deal and got a different diagram. Apparently the diagram you posted is for Maximas made from 06/2000-06/2001. Mine was manufactured 12/99 and has a slightly different diagram with no plate showing, that's why I couldn't find it. But there IS a plate there on the actual car, just no gasket behind it. And you have said you didn't have a gasket, and I didn't have a gasket, and I watched a guy on YouTube take his apart and it didn't have a gasket either. But Nissan put one there later in production?
I can't believe the black plate isn't even in my diagram, that's what threw me off. Here is mine:
Old Dec 1, 2021 | 07:56 AM
Others can comment, but it is not uncommon for parts diagrams to change and/or be off. I'm 100% positive that my TB has never been off before me and there was no gasket there.
holymoly
Jul 16, 2011 03:12 PM
gdal
Dec 10, 2010 05:02 PM
matty
Aug 11, 2006 03:30 PM
acidspit86
Jun 8, 2003 07:53 AM
