Help no power when pressing on gas!!
Old Jan 27, 2022 | 09:59 PM
Jonrt87's Avatar
I’ve been experiencing this problem for a couple weeks now it wasn’t too bad til today when I went out
my car COULD’NT switch gears I kept putting it into drive but it wouldn’t switch it was stuck in reverse
also when I started driving as I pressed on the gas my car would not move i would rev it and nothing happened and it kept slipping
as I reved my car it moved for just a second and then it kept repeating this viscous cycle (no power when I pressed gas, moved for second repeat)
I went to Auto Zone last week the code came up as P0011 there might be another new code i’m not sure
so my question is what do I need to replace or what do I need to go buy?? i’m definitely not trying to bring my car to the shop I’ve repaired my car in the past before as long as it’s not too tedious I can do it
any help would be greatly appreciated i’m about to start a new job I NEED this to be fixed ASAP
Old Jan 27, 2022 | 10:16 PM
Transmission might be toast. I'm assuming your auto. Start by checking the fluid level.
Old Jan 27, 2022 | 10:26 PM
Jonrt87's Avatar
How do you know if it’s transmission related??
it’s crazy cause my car was just driving fine it was still doing everything I said but was VERY minor wasn’t an issue but it never just not moved when I pressed on the gas
If it’s the transmission imma just junk the car F IT
Old Jan 29, 2022 | 04:32 PM
uptownsamcv's Avatar
ever had the transmission serviced before?
#1 killer of automatic transmissions is people slacking off on servicing them.
Old Jan 31, 2022 | 10:08 AM
Ksnelgrove's Avatar
Based on the CODE thrown, it's a VVT (Variable Valve Timing) Issue. This is a good link to troubleshoot and fix: https://www.700r4transmissionhq.com/...nissan-maxima/
Old Jan 31, 2022 | 04:25 PM
Well, for starters, are you auto or manual?
If manual, the clutch being toast is another possibility.
petro2342
48
Mar 3, 2009 05:37 PM
dawalkster
Jun 9, 2007 11:24 AM
Brandon90gxe
Jun 21, 2001 12:19 PM
