Is it worth replacing knock sensor?
Old Feb 4, 2022 | 05:33 PM
uapride's Avatar
I have 2001 Nissan Maxima GLE 3.0 V6. I need to replace the intake manifold gaskets, and sins I have to remove the upper and lower intake manifolds, and knock sensor is right under the manifold, should I replace the knock sensor as preventive maintenance or just leave it alone. Thanks
Old Feb 4, 2022 | 07:37 PM
Reality sucks's Avatar
Yes, be sure to replace its harness also.
Old Feb 5, 2022 | 10:28 AM
Turbobink's Avatar
+ 1 on the yes response.
Old Feb 5, 2022 | 04:11 PM
maxinout93's Avatar
Yes it worth it
Old Feb 7, 2022 | 10:29 AM
Prophecy99's Avatar
why? i have my original.... an don't see any reasons to replace it if it is not broke
Old Feb 26, 2022 | 01:12 PM
JvG's Avatar
JvG
Because it's a lot more difficult to replace when the intake manifold is in the way.
Old Feb 28, 2022 | 11:09 AM
Prophecy99's Avatar
i hear yea, im just saying i haven't heard of anyone having to replace it before, and haven't heard of people having issues with them. and "just because" isn't all that great of a reason.
the code for the knock sensor comes up %99 when other codes pop up, and it is considered a "piggy back" code, and each time i have had the knock sensor code, it has gone away when i resolved the other pending codes hence being a "piggy back" false positive code.
Old Feb 28, 2022 | 03:55 PM
Wonder if you can bypass it with a 470k ohm resistor like the 4th gens. I would if you use 91 or 93 octane fuel.
Old Mar 1, 2022 | 01:19 AM
Veewee's Avatar
Yes you can bypass it with same method, but for me I use 560k ohm resistor and 91 octane fuel....
Sadly the engine pinging like crazy whenever I hit the throttle more than 15%....
Old Mar 2, 2022 | 07:27 AM
Prophecy99's Avatar
im confused, if the manual says 91 octane recommended, why would u need to bypass the knock sensor if you are using suggested octane?
i use 93 as well with advanced timing 2 degrees
Old Mar 2, 2022 | 07:50 AM
Bypass it to not go through the hassle of replacing it lolol
Old Mar 7, 2022 | 09:50 AM
Prophecy99's Avatar
ahh , now i follow.. =)
AcuraLegend
Nov 28, 2014 09:26 AM
motocross416
Jun 27, 2004 10:51 PM
PhatBastard
Apr 23, 2002 05:08 AM
JULIAN
Oct 23, 2000 12:22 PM
