View Poll Results: What should I do?
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Can't seal H2o Pump. WTH?
Attempting to R & R water pump 03 Maxima GLE. Brand new aftermarket pump, brand new Nissan seals. Installed and reinstalled pump several times. No matter what I do... Water added to the radiator pours out the weep holes. Adding water to the radiator in order to check for a good seal before buttoning everything up. No water should come out of weep hole if the pump is sealed properly into if housing on the inner timing cover... Correct? With every failed attempt, I remove the pump, inspect the seals, inspect the housing, and everything looks perfect. With this last attempt, I threaded the big nut on to the large idler pulley stud so that I could use a long screwdriver to push the pump and seal into position. Did require some Force... Indicating some resistance as the seal is compressed against it's inner timing cover housing. Then install the bolts to hold it in place. Same result. Water poured in the radiator comes out of the weep hole. If I pour the water in quickly... It comes out the upper whole as well as the lower one. The water doesn't trickle out. It comes out in a stream as if there is little to nothing interrupting it. Can anyone offer an explanation? I don't see how I can install the pump any better. Done it half a dozen times... So I'm pretty proficient at it by now. I have removed the AC compressor and alternator to verify where the water is coming from. Precisely from the to weep hole locations. I was actually able to get my eyeballs on the top one, with the thermostat housing removed. And yes... New gasket for the thermostat housing. Not leaking from there. Has anyone had this issue before? It doesn't seem to matter what I do... I can't get the pump to seal. Or rather... I can't get water poured in the radiator to not exit the weep holes after installing the new water pump. Sure like to figure this out. It's a beautiful car... Silver with Dove gray interior and about 150k.
H2o pump WTH?!
