swap question, tensioner
Old Mar 7, 2023 | 03:12 PM
uptownsamcv's Avatar
I'm in the process of prepping my 2014 engine to be swapped into my 02 and I'm stuck on what to do with the Nisformance tensioner bracket. I put the hardware into it the same way as it was stock and it doesn't line up right. am I doing something wrong?
Old Mar 8, 2023 | 03:53 PM
Reality sucks's Avatar
Kinda.. But not really. That bracket may be made slightly different than the OEM but to fix your issue bend the bolt slightly to get it straight if you want Just so long as it clears the belt and runs true. The angle of this doesn't matter so much. The center bolt being tight is what locks in the adjustment. Once the center nut is torqued you could back the adjuster off and the belt wont move.
Old Mar 9, 2023 | 12:32 PM
I put it in place with a dummy tensioner in place of the compressor and just tightened the belt and it all went into place. no clearance issues or anything..
frank5079
Oct 6, 2018 07:31 PM
tdewitt34
62
May 4, 2009 12:01 PM
VeN0m
May 5, 2006 06:40 PM
dadonfromqueenz
Apr 5, 2006 05:47 PM
