IACV question
Old May 16, 2023 | 11:31 PM
Oklahoma's Avatar
IACV question
I got the p0505 code. Pulled ecm and inspected it, it looked fine. I have designed my own MOSFET aray using much betters MOSFETs. I am also adding built in over current protection into the circuit, I'm just waiting on the PCB prototype to arrive so I can assemble. I added 10 pins spaced at 2.54mm pitch so it will solder right into the original pads.
I pulled my IACV to check that it's operating correctly when the key is turned to the run position. See following video seems like a self test bc the pattern stays the same everytime the key is turned on. The car runs and idles fine drives good as well.
https://youtube.com/shorts/R_57dhfV8OA?feature=share
Tarzan
Jul 7, 2017 12:28 PM
shadyonedeath
Oct 20, 2009 06:32 AM
JamesNH
Mar 27, 2008 05:03 PM
Gapp
Jul 1, 2006 08:06 AM
