Alternator whine
Alternator whine
Got a 03 I35 and the alternator has been making this whine sound for a few months, im assuming the bearing have gone bad on the pulley possibly? I wanted to know if the alternator pulley can be removed from the alternator while its still on the car? Has anyone done this before. Ive already replaced the idle pulley to rule that out as well as the belt. The noise is anytime the car is running, seems to be getting louder now.
Mine did the same thing, started with the metallic whine (almost sounded like a SC) and then it wasn't making enough voltage to support the additional electrical load. (AC, headlights, etc)
Had it tested at Autozone and it failed the diode test. Voltage across battery was under 12V with engine running at 2K RPM. It might be time to replace the alternator before it kills the battery and leaves you stranded.
it's not a hard alternator to change out. just be careful unplugging the connector. you might want to actually order a new sub harness for the alternator, I'm on my 3rd..
https://www.ebay.com/itm/16522856917...6vI5i&LH_BIN=1
Jagalag
Aug 20, 2019 05:43 AM
Dogg
Feb 25, 2011 02:22 PM
keener
May 18, 2002 06:53 PM
