Camber Issues!!!!
Old Jun 14, 2024 | 06:23 PM
Chippewaking98's Avatar
Camber Issues!!!!
I have an infiniti i30 2000 same car believe as the 5th gens. Installed lower controls arms,struts,axles, sway bar links etc. The whole front end. Both wheels are chambered positive or the tops leaning outward. What did I do wrong or how can I fix it
Old Jun 14, 2024 | 08:25 PM
Child_uv_KoRn's Avatar
Bad *** Newb
has to be wrong struts. If it's not terrible, then you can use camber bolts...but this sounds ****ed up lol.
I was lowered at least 2" and camber bolts off ebay worked just dandy.
Old Jun 15, 2024 | 12:21 PM
Okay ill be getting new ones then thanks. Any opinions on which struts i should get? And also I went to replace inner tie rods and theres a small clip on the end closest to the rack and pinion. I couldn't get that bolt loose wondering if that clip comes off some way specific. Thanks man. My number is 260-343-1682 if texting is quicker
Old Jun 15, 2024 | 04:38 PM
I called and it the part number is the right strut. I even check if I fit it on right. Lower control arms look good too. Look the same as old struts too. Camber is still too positive
Old Jun 16, 2024 | 11:25 AM
westdude's Avatar
What's the make / part number of the front struts / lower control arms you used?
54500 - LINK COMPL-TRANSVERSE,RH 54500-2Y411
54500 - LINK COMPL-TRANSVERSE, LH 54501-2Y411
54302K - STRUT KIT-FRONT SUSPENSION,RH
54303K - STRUT KIT-FRONT SUSPENSION,LH
Old Jun 16, 2024 | 05:44 PM
I bought everything from detriot axle. I put the old struts back on even though they're needing replaced and the camber issue was solved. I'm returning the struts. Any suggestions on some good struts?
Old Jun 16, 2024 | 07:50 PM
westdude's Avatar
original parts still available
https://www.nissanpartsdeal.com/part...MT)&pnc=54302K
https://www.nissanpartsdeal.com/part...MT)&pnc=54303K
Old Jun 17, 2024 | 06:34 AM
uptownsamcv's Avatar
I'm running KYB struts with Tein springs, 2.2" drop front and 1.6" rear with no issues. the only time I ever had camber issues is when I had a bad strut mount on the passenger side front . I've had this car lowered since I got it and never needed camber correction bolts. it was lowered for the first 10 years with Megan Racing springs before I decided to go lower and switched to Tein this past November. still no camber issues.
Old Jun 17, 2024 | 06:38 AM
😮Dayum those are expensive!!😮
I'm sticking to KYB's
Rennmeister
Sep 20, 2017 08:22 PM
BlazedHoisanLo
Dec 18, 2014 10:11 AM
96CefiroI30
Oct 23, 2012 11:29 AM
jtreed2000
58
Apr 12, 2006 12:57 PM
A5295
Oct 28, 2003 09:42 PM
