Random Tech Cat instructions and components
Old Feb 19, 2002 | 07:47 AM
PhatGuy
What components are supposed to come with the RT Cat?
I have:[list=1][*]The Cat[*]2 gaskets[*]2 bolts[*]2 headless bolts[*]6 lock washers[*]3 nuts of one size[*]2 nuts of another size[*]1 nut of even another size with some sort of washer jammed on it[*]one larger washer[/list=1]
Anyone have a list of what exactly I need to install this plus the basic install instructions. What was the consensus on heat shield facing up or down?
Thanks!
Old Feb 19, 2002 | 07:56 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
I didn't get the install kit... just went to Home Depot and bought 2 bolts, 2 nuts, and 4 washers... reused the stock gaskets.
Heat shield faces upwards.
Old Feb 19, 2002 | 08:06 AM
PhatGuy
What is the best way to clean up the gaskets? I bought this used from another .org member so trying to figure out what is needed since I got this pile of hardware. What do I need these headless bolts for?
How long should the install take at a skilled and reputable shop? (I always pay cash and work the deal out before install)
Old Feb 19, 2002 | 09:35 AM
Y2KevSE's Avatar
Sorry, I used 4 bolts, 4 nuts, 8 washers. Forgot about the other side.
Use brake cleaner to clean the gaskets.
Headless bolts? No need for them. Use the hardware I listed and you should be fine.
Install depends on if your bolts are seized up or not. Should take anywhere between 15-60 minutes. Again, this depends on your nuts....
... and bolts of the stock cat.
Old Feb 19, 2002 | 09:55 AM
RussMaxManiac
Re: Random Tech Cat instructions and components
All that comes with the Cat is the Cat, and thats it.
You buy the gaskets, bolts, washers, etc. I had to use what I had in the garage to make it work. I gave them to you when I sold you the Cat.
Thanks!
Old Feb 19, 2002 | 09:57 AM
RussMaxManiac
Headless bolts are the stock bolts that are on the car. They just screw into the cat (stock cat). The guy I got it from used those. Use bolts on each side of it.
Old Feb 19, 2002 | 12:17 PM
MyownNismo's Avatar
Future Camaro SS owner
hey Y2KevSE what size cat you get 2.5 or 3 inch since you have the Greddy Catback.
Old Feb 19, 2002 | 12:24 PM
Y2KevSE's Avatar
2.5" 3" would be an overkill on an NA car.
Old Feb 19, 2002 | 12:27 PM
MyownNismo's Avatar
thanks for the info also I know you have the y-pipe but I was wondering if you think it is to loud to use on the highways and public roads.
Old Feb 19, 2002 | 12:54 PM
Y2KevSE's Avatar
The answer to this depends on taste/preference. I don't think my exhaust setup is loud, but that's relative.
This video is with a CAI, Stillen y pipe, RT Cat, and Stillen muffler:
http://wwwcsif.cs.ucdavis.edu/~chin/...ht_01Mar17.mpg
... which was way louder than my current setup Stillen SC, Stillen y pipe, RT Cat, GReddy cat-back:
http://wwwcsif.cs.ucdavis.edu/~chin/...ie/01Oct30.mpg
Old Feb 19, 2002 | 09:24 PM
PhatGuy
Thanks! How long can the bolts be? Do the 8 washers need to be lock washers?
Old Feb 19, 2002 | 09:26 PM
PhatGuy
Can't wait for the new video of the greddy reved up inside and out!
Old Feb 19, 2002 | 10:43 PM
Y2KevSE's Avatar
Not too long and not too short. I suggest measuring your stock bolts and go with those measurements. Nope, no need to be lock washers.
Old Feb 19, 2002 | 10:44 PM
Y2KevSE's Avatar
I should be able to get videos of my dyno runs this Sunday.
Old Feb 20, 2002 | 01:56 AM
MyownNismo's Avatar
The one with the CAI is that with the windows down or up.
Old Feb 20, 2002 | 04:40 AM
UMD_MaxSE's Avatar
Got Bent?
ditto
Old Feb 20, 2002 | 06:48 AM
Y2KevSE's Avatar
Up. Loud, huh?
Old Feb 20, 2002 | 09:24 AM
PhatGuy
Old Feb 20, 2002 | 12:05 PM
MyownNismo's Avatar
I am so getting my y-pipe and RT cat. Got a Greddy and PRCAI is coming.
maxinout93
Oct 31, 2015 02:04 AM
RealityCheck
Oct 2, 2015 06:34 PM
Redfox
Sep 28, 2015 10:41 AM
