2k2 Maxima engine vs. 350z engine
Old Feb 19, 2002 | 08:21 AM
Chitwista's Avatar
I was at the Chicago Auto Show at took a look at the new 350Z.. From what they were saying it has the same 3.5 engine as the Maxima.. However they said that it is capable of over 280hp.. Is it simply a couple of differences in the computer, if so do you think that Nissan will release some sort of programming to increase the preformance of the 3.5 Maxima engine.. WHAT DO YOU GUYS THINK.. I am still new to this so take it easy.. PLEASE
Old Feb 19, 2002 | 08:26 AM
PhatGuy
I personally think it is more than just the ecu. Probably the intake and exhaust as well. To early to know right now....
Old Feb 19, 2002 | 08:30 AM
ru4real's Avatar
Re: 2k2 Maxima engine vs. 350z engine
Obviously there must be differences in the intake and exhaust manifolds and maybe the cams are slightly different, but if a lot of performance can be gained from reprogramming, I think Nissan could make some money selling a warrantied upgrade to 2k2 Maxima owners. That'll never happen.
Old Feb 19, 2002 | 08:34 AM
Colonel's Avatar
Old Fuddy Duddy
There is no way
Nissan is going to let their 4door have the same HP as their sports car. Marketing thing...but also my opinion.
Would be nice to have that capability though....
Old Feb 19, 2002 | 08:40 AM
theblue's Avatar
Re: There is no way
do you remember the 300Z line up an automatic Z against a maxima and see what happens
Old Feb 19, 2002 | 08:57 AM
ripper's Avatar
I think I read (somewhere) that the Max has variable timing only on the intake whereas the Z has it on the exhaust as well.
Old Feb 19, 2002 | 11:03 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
It should be interesting to see what kind of aftermarket support the 350Z gets.
Hopefully, between NISMO and the aftermarket some of the parts will be similar enough to swap over to the 2K2.
Old Feb 19, 2002 | 11:05 AM
2M0A0X2's Avatar
we have it on both exhaust and intake
Old Feb 19, 2002 | 11:11 AM
sardarg89's Avatar
nope, we have both!
Old Feb 19, 2002 | 11:25 AM
Jeff92se's Avatar
I'm needing a caw
From what I see on the engine, the maxima only has the timing control assemblies mounted on the intake cams.
Originally posted by sardarg89
nope, we have both!
Old Feb 20, 2002 | 06:48 AM
sardarg89's Avatar
is variable timing on the intake and exhaust not the same thing as the variable intake manifold and variable-capacity muffler?
Old Feb 20, 2002 | 07:12 AM
ru4real's Avatar
Yes. Variable valve timing on the VQ35DE is not the same as the variable intake runner or muffler.
Old Feb 20, 2002 | 07:14 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
I believe Jeff is right - the VTC on the VQ35, at least on the Maxima, is only on the Intake valves and varies phase only and not lift.
The variable intake manifold and variable muffler are completely different things. VTC controls valve timing whereas the manifold controls the air supply before the valves and the variable exhaust varies backpressure after the exhaust valves all the way at the end of the exhaust system.
Old Feb 20, 2002 | 07:24 AM
sardarg89's Avatar
sorry...
although I know the difference between valve timing (phase/lift) and variable intake manifold/variable capacity exhaust, I was too stupid to realize that he was talking abotu the intake/exhaust valves (when he mentioned timing, it should have been obvious)...
Hawkeye61
Aug 12, 2015 06:45 PM
laparka66
Aug 6, 2015 09:36 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
BassAddictJ
Aug 4, 2015 11:38 AM
